Marine Headliner - Fiberglass RV
Old 03-27-2021, 05:39 PM   #1
dgb
Trailer: Cadet n126d
Question Marine Headliner
If I use marine headliner, do I need to sand the walls and clean them first? There's bits of old dry rotted foam on the walls and ceiling.
Also, do I need to put something behind the marine headliner?
I'm a total newbie, so please help me!
I have videos showing the camper, on my YouTube channel. www.YouTube.com/c/CampingTherapy
It's a 1987 Cadet.
dgb is offline   Reply With Quote
Old 03-28-2021, 12:07 AM   #2
David B.'s Avatar
Doreen, the headliner will show any imperfections of what is under it, plus not much of an insulating factor. Reflectix is an aluminized bubble wrap type insulation that should be glued to the the interior first (no need to get all the old glue off, just anything loose) with all the seams covered with aluminum duct tape, then the headliner. I have heard that Scamp uses two layers of reflextix under the headliner. I have found that using a dry paint roller to affix the headliner to the reflectix works better than using hands, as hands tend to stretch the ply able liner which results in wrinkles. Best of luck with your project. There is another type of marine headliner that is smooth vinyl, backed with foam rubber, so reflectix wouldn’t be needed as the foam is the insulating factor.
Dave and Paula
Old 03-28-2021, 08:14 AM   #3
Dave and Paula
Scamp uses a single layer of Astrofoil, which (like Reflectix) sandwiches two offset layers of bubble wrap (bubbles on one layer align with gaps on the other) between outer layers of foil. Their description is a bit unclear on that.
Old 03-28-2021, 07:31 PM   #4
TN
To get good glue adhesion you will want to remove as much old material you can. I found a 4" angle grinder with a flappy wheel sanding disk worked best but you have to be careful not to get carried away and remove to much and start digging into the glass. After that you will want to clean the surface with an grease and wax remover. Then you can start applying the adhesive. Don't worry to much about the old glue as the new glue will bond with it.
Eric Frye is offline   Reply With Quote
Old 03-30-2021, 01:06 AM   #5
Trailer: 1975 Boler 1300
One nice thing about the marine headliner is that velcro sticks to it very well. In my Boler, that is a blessing since I'm not too crazy about riveting anything to it i.e. curtain rods
Argus is offline   Reply With Quote
Old 03-30-2021, 07:44 AM   #6
dgb
This is what I ordered. I'm putting up reflectix today.
https://www.ebay.com/itm/TAN-Un-Back...-/223923416047
Old 03-30-2021, 10:01 PM   #7
charlsara's Avatar
Trailer: 2014 Lil Snoozy
Be sure to use high temperature contact cement if you want it to stay when it gets hot from the sun.
Old 03-30-2021, 10:07 PM   #8
dgb
Spray Adhesive
Yes, I bought the good stuff. I used 3 cans today, just putting reflectix in 1/2 of the camper. I'm gonna buy 10 more, to make sure I have enough.
I bought Permatex Heavy Duty Automotive Headliner Adhesive.
Just marine headliner fabric on Scamp... no insulation? rexrogers Problem Solving | Owners Helping Owners 7 03-31-2018 06:53 PM
Marine Headliner Seams Johnny M Problem Solving | Owners Helping Owners 7 01-22-2017 02:45 PM
Yet another headliner question. Davie B Problem Solving | Owners Helping Owners 3 12-20-2009 04:19 PM
New Headliner for your older fiberglass trailers. Cheryl Libby Modifications, Alterations and Updates 0 02-18-2008 11:40 PM
Headliner: it is sticky Stephen Moody Problem Solving | Owners Helping Owners 6 10-29-2007 12:01 PM
