Hi all,
I just want to share some of the mods/upgrades I've done so far since I got my
Scamp 16 in 02/2021. To start, I have a 2019
Scamp 16 Layout 6 without AC and 3-way
refrigerator.
Here are some of the stuff I did. I probably forgot some other upgrade/mods along the way.
- Interior & exterior LED
light bulbs
- Progressive Industries surge protector and display
- Hall sensor voltage & amps meter
- 12V only Recpro/Everchill 4.3 cu-ft compressor
refrigerator
- 12V computer fan with switch on the bottom to pull cool air for the
fridge
- Installed new 100ah deep cycle AGM
battery to support the new
fridge
- Curt breakaway switch for emergency braking
- Reflective white/red stickers on the A-frame front and rear bumper
- Wireless rearview camera
Propane tank cover with a hole on the back for the
propane hose
- Tarp
awning with suction cup and extendable poles
- Added a rear hitch cargo carrier for portable waste tank,
generator, & gas tank
- Interior
lights (battery powered) for all closets (no pics shown)
- Multi-color
LED lights with remote control under the bellyband (hardwired)
- Removable AC bracket for window AC unit
- Repainted trailer tongue
- Removed
battery box
- Added addition trailer stabilizers at the front
- Added a tongue box
- Cut a whole in the bottom of the box to fit the 20lb
propane tank
- Installed two 100ah LifePo4 Renogy
battery with bluetooth in parallel
- Installed a Progressive Industries battery charger for lithium batteries
- Renogy battery monitor with shunt
- Renogy DCC30S DC-DC charger (from alternator) with MPPT for
solar charging
- Renogy BT-2 bluetooth for use with DC Home app for DCC30S charging
- Battery cut-off switch (not shown)
- Some other mods I forgot...
To be installed:
- Run 6 AWG wires from tow vehicle battery to the back of the hitch with Anderson connector
- Run 6 AWG wires from Renogy DCC30S DC-DC/MPPT charger along the 7-pin cable and terminate with another Anderson connector
- Run battery monitor cable from tongue box from the bottom of the
Scamp into the top of the front closet and installed the display
- Install Renogy 175 watt flexible
solar panel on the roof, drill a whole, and run cables down to the front closet of the Scamp.
- Install
awning track from Sailrite using VHB tape for tarp
awning instead of using suction cups
- Other projects TBD.
Let me know what you guys think. Thanks all.
