Mounting The Ultimate Trailer Jack to a Pole Tongue Hymer - Fiberglass RV
Old 01-30-2020, 01:29 PM   #1
OCJohn's Avatar
Trailer: Hymer
The trailer jack that came with our Hymer was a cheapo, fold-up deal rated for 1000lbs. Capacity was fine. The trouble was, it's lowest height wasn't always low enough to get the trailer level on uneven ground. After finishing the tongue extension the problem was worse, and it was too low be dropped into place even on level ground.
I found my solution with the Ultimate Trailer Jack. Trouble with that, however, was it came only with a three-hole flange mount for an A-frame tongue... My workaround was to cut off the flange and weld the base collar to my own bracket. Works slick, and the adjustable starting height makes it much faster to raise and lower.
NOW I'm ready for Quartzsite!
OCJohn is offline   Reply With Quote
Old 01-30-2020, 01:38 PM   #2
Very nice!
Old 01-30-2020, 01:44 PM   #3
Or you could have made a bracket to accept the three bolt flange. I did that with our teardrop camper. Your solution looks good. Since the jack is kind of sloppy in the mounting tube I didn't trust it to stay up while traveling so I have a short chain from the tongue to the jack foot that clips on for travel. I also modified the guide groove so I can pull the jack up out of the base if I want. I do like the Ultimate Jack and it works good for me to open the truck tailgate with the trailer hooked up.
Old 01-30-2020, 01:50 PM   #4
OCJohn's Avatar
Trailer: Hymer
I definitely didn't take the easy route. But to be honest, the scariest part of the project was drilling the 2 3/8" hole. (I really hate hole saws...)
Old 01-30-2020, 02:05 PM   #5
Doctor Harold's Avatar
Trailer: 1975 Scamp, 13-foot
Redding, California
Very nice!!
You cannot have a proud and chivalrous spirit if your conduct is mean and paltry; for whatever a man's actions are, such must be his spirit. --Demosthenes
Doctor Harold is offline   Reply With Quote
Old 01-30-2020, 07:04 PM   #6
That bracket looks great. Did you fabricate it. Had you thought about welding it on the tongue instead of the bolts. Nice work, I like it !
Old 01-30-2020, 08:01 PM   #7
OCJohn's Avatar
Trailer: Hymer
Thanks. Fab work is mine. Its just 5x5x3/16 square tube cut at about 30 with a plate stuck on the back. I ruled out welding on the tongue for a couple reasons. One, Ive never taken nor passed a welding test. So even when my welds look okay (not a given), Im more confident on items that I can start over on if I screw up.
The other reason for a bolt-on is the Hymer tongue is galvanized and Id rather not burn off the zinc coating. If I ever get so ambitious that I replace the stock tongue, I might not be so squeamish.
Old 01-31-2020, 10:53 AM   #8
Timber Wolf's Avatar
North Florida
I put the Ultimate Jack on the tongue of my old Scamp and like it a lot. At the camp ground and site I set up at the most the ground is pretty sloped and the Ultimate makes short work of it. Over the years I have blocked up the low side, then started digging in the high side. But recently I discovered that by canting the trailer in at an angle it is actually level side to side as is! Then I lower the jack till the tongue is a couple of inches off the ground and I am set. It is low enough at the door to do with out an extra step but I usually set one up anyway, but I have to dig it in.
Old 01-31-2020, 11:11 AM   #9
When I rebuilt and extended the frame on my 16' Scamp I used a Bulldog hitch with the mounting included like this:
This forms the 55* angle that I used when building the front part of the frame.
This jack works great and I use it to tilt down the trailer to put the rear stabilizers down and then back up to load them.
After that I raise the front and drop the two stabilizers I installed under the frame to help the wobble in the front.
Old 01-31-2020, 11:27 AM   #10
Trailer: R-Vision & In the market
Massachusetts
Yeah trying to weld Galvy is tough. You really have to grind it off and then it will rust. When I worked for Mercedes they had a great product called Zinc dust to touch up any exposed metal that wasn't covered with the body paint. It was finely ground zinc in some kind of a clear paint base. I worked great. It dried a dark grey and it stopped rust in it's tracks. I bought a quart more than 20 years ago and it was well over $50.00
ThomasC is offline   Reply With Quote
Old 01-31-2020, 12:15 PM   #11
OCJohn's Avatar
Trailer: Hymer
Originally Posted by redbarron55 View Post
When I rebuilt and extended the frame on my 16' Scamp I used a Bulldog hitch with the mounting included like this...
Yeah, you've got a lot more options with an A-frame tongue. This is what I'm dealing with:
Old 01-31-2020, 08:22 PM   #12
WaltP's Avatar
Trailer: 2017 Escape 17B
SW Virginia
John
Nice work. Sure glad I haven't had to deal with a pole tongue. Hope I get to see your rig next week.
Walt
Old 01-31-2020, 10:59 PM   #13
OCJohn's Avatar
Trailer: Hymer
Look forward to meeting you Walt. I doubt we’ll be hard to find.
Old 01-31-2020, 11:56 PM   #14
Raspy's Avatar
Trailer: Black Series HQ19 on order
Smith Valley, Nevada
My solution to the jack not reaching far enough down, was to make brackets that mount it below the frame, instead of straddling the frame. Then I built a foot with extension that telescopes up into the jack. This allows it to either have a wheel, or a foot. The foot has a pin and drops out if not needed.
Raspy is online now   Reply With Quote
hymer, pole tongue, tongue jack
3x3 Pole Tongue Extension for a Hymer GT OCJohn Modifications, Alterations and Updates 14 02-01-2020 02:08 PM
"Ultimate Jack" removed from market? gordon2 Modifications, Alterations and Updates 16 03-28-2018 03:47 PM
Ultimate Trailer Jack minnfinder Towing, Hitching, Axles and Running Gear 50 05-05-2017 05:42 AM
Tongue box mounting multi-task Modifications, Alterations and Updates 5 04-30-2013 11:31 PM
