I Picked up this 72
Boler at the end of last
fall. It sat all winter and I waited for the snow to stop so I could start working on it.
The trailer came pretty tidy on the inside with the walls being scrubbed and all the wiring and
propane lines pulled.
Things I've done since I've had it:
-Replace the flooring with Wood Laminate.
-Did all the trailer wiring, along with adding the marker
lights, and adding LED
tail lights.
-Redid the 110v wiring. Added 3 outlets, 2 on the counter and 1 inside the cabinet by the
fridge insert. The wiring was done to a breaker box with 2 15amp breakers.
-Cut some shelves for the cabinet.
-Redid the countertop with one I found at Ikea. It had to be cut to size. I just used a Circular saw with a 120tooth blade. I cut the holes for the sink and stove with a jig saw.
-I decided to
paint the outside with Interlux Brightside
paint. First I've primed it with Interlux Primer. I've decided to do White and Sea Green. The
painting is a little hard as the PO decided to coat the front and back with truck bed liner. This adds a bumpy texture, I've sanded as much as I've wanted to to flatten it out.
I'll post some pictures of the finished
paint in a bit
