There is a good chance you will see some ghosting, as the gelcoat underneath will not have been exposed to UV attack. Most folks just put it back in the ghost zone. It might also help to use some painters tape to keep you aligned during application. Offset a pencil line 3 inches from (bottom or top of letter or stripes,, i.e. edges) where you will be applying the sticker. Put your tape strips there, out of the way of scrappers and WD40 or GooGone or whatever you choose to clean with. Once it is all clean, make some tiny pencil tic marks offset 3" back into your application zone. Don't engrave them, you just want them to be visible, but easily wipe off with your finger. Hopefully, that will keep you aligned properly.
