Portable Air Conditioner - Anyone Try It? - Fiberglass RV
Old 07-06-2020, 07:39 PM   #1
barryra's Avatar
Trailer: 1993 13 ft Scamp
Has anyone tried one of these portable air conditioners? We cooked this last weekend in our 13 Scamp & was hoping this may work.
Thanks for your info & please let us know how to attach to window etc.Click image for larger version
barryra is offline   Reply With Quote
Old 07-07-2020, 06:23 AM   #2
https://www.fiberglassrv.com/forums/...amp-51948.html
https://www.fiberglassrv.com/forums/...per-88168.html
https://www.fiberglassrv.com/forums/...-rv-59659.html
https://www.fiberglassrv.com/forums/...ner-42817.html
Old 07-07-2020, 10:18 AM   #3
Raz
Raz's Avatar
I tried one a few years ago in my home and was not impressed. After two nights with very poor performance I returned it. A small room air conditioner worked far better.
Old 07-07-2020, 10:51 AM   #4
Tom Y's Avatar
We tried a 8k BTU unit in our Bigfoot TF20, about 16ft of living space plus the overhead area. During a real hot spell, it was barely able to do the job. The issue I have with these is the air used to ventilate the hot side is sucked from inside the camper, then it blows it out that duct. This in turn pulls hot air from outside into the camper making it harder to keep it cool inside.
So if I were to do it again I would not get one any smaller than 9k BTU, and if you look hard you can find one that has a accommodation to add a second hose that sucks the air for the hot side from outside too. That would make a huge difference.
Tom Y is offline   Reply With Quote
Old 07-07-2020, 11:19 AM   #5
Trailer: BigFoot
My two sons live in San Jose, CA and both have these air conditioners in their bedrooms and they work very well. The house they live in does not have AC and becomes quite hot. Get the largest available. We were shocked when we went to visit and learned that almost no one has AC in the San Jose area.
2019 Big Foot 25RQ with cargo box, onboard Cummins LP 2500 generator, solar panels, and 2019 Ram 2500 4x4, 6.7L Cummins with ARE Shell.
Rzrbrn is offline   Reply With Quote
Old 07-07-2020, 11:28 AM   #6
Alex Adams's Avatar
Trailer: 1979 Boler B1300
New Hampshire
The problem with these is the hot air has to be expelled outside. The tube used to expel the hot air is not insulated and acts like a radiator. It does get quite hot. My next door neighbor used to wrap an old blanket around the tube to cut down on the heat being radiated back into the room.
Old 07-07-2020, 11:40 AM   #7
Trailer: BigFoot
Bubble wrap works also. Simple hacks to increase efficiency. Wish I had one of these when we were young and tent camping. I suspect these would work well with a smaller Big Foot which is well insulated. Also they are quite large relative to a small FB trailer.
Old 07-07-2020, 12:29 PM   #8
rdickens's Avatar
Trailer: 2017 Scamp 16 Deluxe
Barry,
Instead, I might suggest mounting a 5000 BTU Frigidaire window unit in the back (slider) window of your Scamp after you arrive at a campsite (you can't [or at least shouldn't!] travel with one of these in the back window.)
We have used a 5000 BTU window unit in both our 2014 Scamp13 and our 2017 Scamp16 Deluxe Layout A. It isn't as convenient as a top-mounted unit but, it is much quieter, cheaper, and it has cooled both trailers very well.
You can probably find several designs of mounting platforms on earlier forum posts.
It took a couple of design attempts but, I've now created a mount that protects the window and window track, supports much of the weight down to the rear bumper of the trailer, and prevents rain and bugs from coming into the trailer.
I think that I've heard that the rear window of most/all Scamps since 1985 will open (both glass and screen) wide enough to accommodate the Frigidaire 5000 BTU unit (possibly other small units as well?). Still, you should open your glass and screen, measure the opening, and compare dimensions to whatever window AC you decide on.
After opening the window and screen, I pad the window track (bottom) and the top and side edges with either split pool noodles or rubber pipe insulating foam. I then put a 2-piece wooden frame (1/4" plywood + 1" x 2.5" to 3" pine) into the opening that pulls up tight against the foam/pool-noodles (with bolts and wing nuts) to seal out rain and/or bugs. (That frame also protects the side glass and trailer fiberglass against any damage that might otherwise happen while lifting the window AC into place.)
I then put a wooden platform over the wooden window frame and support the back edge down to the rear bumper of the Scamp (with a PVC pipe) to support some of the weight.
Most of the time, we don't need/want AC but when heat and humidity are too much for fans, we can still have a relatively quiet and cool/comfortable trailer.
I'm still trying to make the whole thing even easier to mount and prettier ... but it works!
Try not to be too critical but, the pix in the following Google Drive link may help you design your own mount:
https://drive.google.com/drive/folde...4L?usp=sharing
Ray
rdickens is offline   Reply With Quote
Old 07-07-2020, 12:42 PM   #9
Trailer: In the market
Illinois
My stepson had one for a very small studio apartment. It was ok, but not great. Different brand though. We just scrapped it a few weeks ago after it was sitting unused in the garage for a couple years.
jcj380 is offline   Reply With Quote
Old 07-07-2020, 01:13 PM   #10
Trailer: Companion
Ohio
We used a portable A/C unit and also found it to be very inefficient, takes up too much space in our small camper and the vacuum it makes draws in water past the door seals when it rains. We are doing without until I figure out a way to properly install a 5,000 BTU window unit.
Jim G. - Ohio is offline   Reply With Quote
Old 07-07-2020, 01:36 PM   #11
Trailer: Northern Lite
South Carolina
Portable AC
I have a 5K portable in my Northern Lite TC. It's cumbersome but we find it works OK. You do have to provide a vent source to allow outside air to compensate for what gets blown out the exhaust hose though.
I installed a 14k dual hose unit in my dad's house and it works very well. The first hose draws outside air into the unit and the second hose exhausts the hot, moist air to the outside. There is no negative airspace created and no hot air is sucked into the room.
I have a beef/business opportunity for one of the AC manufacturers. Create a 5 - 8k BTU dual hose AC that is small and relatively light in weight. The world would beat a path to your door.
There is one unit out there, the Climateright 5000, but it's pretty expensive and reviews are mediocre at best. Good luck. Maybe someone will make a smaller dual hose AC unit for RVs that comes in the $350 price range and fits under a dinette or storage space. I'd buy one in a heartbeat because I want to be able to keep my Fantastic Fan.
tschager is offline   Reply With Quote
Old 07-07-2020, 03:10 PM   #12
Trailer: BigFoot
I think rdickens has the superior suggestion, although perhaps a bit cumbersome if you actually travel and only spend a few days in any one campsite. Alternatives to a roof mount don't seem to have many, if any, advantages.
Old 07-07-2020, 04:42 PM   #13
CarlD's Avatar
Trailer: LiL Hauley
Syracuse, NY
room AC in a camper
I am nearing the end of building a new mount for my new AC so I can install it in an emergency exit window. My previous mount fit a 8000 BTU unit which is too heavy and oversized for my Lil Hauley. I used luan for the plywood and reinforced the air conditioner opening and installed weather seal similar to what you find around residential entry doors. I also modified the air conditioner mounting brackets for my application (so much for the warranty). I mounted a piece of wood across the top with a rabbet cut to fit the frame of the window. Two twist latches at the bottom secure the unit in the window frame. The AC unit sits in the opening with a single twist latch at the top to hold it in the frame. When installed I have to tip the AC unit so condensation flows to the outside. I just installed the window today, which is just a piece of lexan and a rabbeted frame to hold it in place. I caulked the outside and will paint it tomorrow.
The air condition weighs 40 lbs and it only takes a couple minutes to remove the screen, install the mounting frame, extend the prop rod and put in the AC unit. In the last two years of camping we have only used an AC unit 5 days. I just carry it in the truck in case we need it.
The reason I took this approach is that the vast majority of the time we don't need it. A permanently installed unit takes up tooooo much room and a roof mounted unit is too noisy, requires a hole in the roof and it wouldn't fit in my garage.
One caveat is you don't want to tip the AC unit when removing it because the accumulated condensation will run out and make you look like you peeed yourself.
Old 07-07-2020, 04:52 PM   #14
rdickens's Avatar
Cost and noise level are the only advantages. (I've heard my sister complain about the noise level from their top-mounted AC and some folks say that, if the top-mount is running, they can't sleep without earplugs.)
As we both agree, alternatives are not as convenient as flipping the switch on a top-mount. Especially inconvenient for 1 night stays enroute to a longer-duration destinarion.
If we needed AC more than 10% of our trips, I guess I might invest in a top-mount and earplugs. [emoji6]
Ray
Old 07-07-2020, 08:27 PM   #15
rdickens's Avatar
Sorry folks!
I guess Google Drive changed some default permissions for sharing?
Try this link again:
And in case that doesn't work, I'll try to attach some smaller embedded pix.
Ray
Old 07-08-2020, 03:19 PM   #16
barryra's Avatar
Thanks for all of the pictures!
Our Scamp has the 2 side 1/2 horizontal sliding windows. Would a 500 BTU A/C work for these windows?
My brother asked about a "Slice" A/C system. Has anyone heard of this?
Old 07-08-2020, 06:46 PM   #17
rdickens's Avatar
AFAIK - The back window is the only one with a large enough opening to accommodate an AC with sufficient BTUs to cool a Scamp.
I have no idea what a Slice is ...
Old 07-08-2020, 06:51 PM   #18
barryra's Avatar
Shoot.... our rear & front window don't open.
Sorry... I meant Split A/C
https://modernize.com/hvac/central-air-conditioner-installation/splitp
Old 07-08-2020, 07:24 PM   #19
Yes a few have installed mini-split heat pumps... There was some concern that they are not built for the frequent vibration from road travel, but it seems they might survive it long enough to make it practical.
https://www.fiberglassrv.com/forums/...its-80173.html
https://www.fiberglassrv.com/forums/...ces-79339.html
https://www.fiberglassrv.com/forums/...nit-58009.html
Old 07-08-2020, 07:49 PM   #20
rdickens's Avatar
https://modernize.com/hvac/central-a...llation/splitp
I thought that the rear window on all Scamps since 1985 opened?
Since your profile indicated a 1993 Scamp, I thought yours would open?
Ray
Portable Air Conditioner Kevin K General Chat 13 04-16-2020 07:54 PM
Has anyone replaced the air conditioner on scamp ROBERT HYSER Modifications, Alterations and Updates 2 06-09-2018 08:02 AM
Anyone Ever Install an RV (Roof) Air Conditioner Thermostat? Bruce H Electrical | Charging, Systems, Solar and Generators 3 08-17-2016 12:11 PM
Anyone try this power converter DannyH Problem Solving | Owners Helping Owners 13 12-04-2009 12:56 PM
anyone try to use a portable floor model AC successfully in a 13 foote lloyd cicetti General Chat 10 09-29-2008 09:22 PM
