Post pics of your Boler replacement blinds. - Fiberglass RV
Old 05-13-2024, 01:32 PM   #1
I am putting the finishing touches on my Boler 1700RG. I'm currently using cheapo vinyl roller blinds from Home Depot, but I don't love them. I've removed the OEM curtain rods and would love something a bit nicer that attaches on the bottom of the window because the windows are at a bit of an angle. What have you replaced your blinds with?
TBlevins is offline   Reply With Quote
Old 05-13-2024, 06:06 PM   #2
steve67's Avatar
Trailer: '79 Boler
on Ontario
Boler Curtains
You can see what we've done on our 1300 using fabric with a darkening backing. We have a clip at the bottom to hold the curtains against the angle of the walls - https://www.fiberglassrv.com/forums/...ler-90495.html
steve67 is offline   Reply With Quote
Old 05-14-2024, 09:21 AM   #3
Nice work Steve! Love the mounting brackets. I also love your cabinetry. Is that baltic birch? I used in in my 1700 but it warped pretty quickly on the doors. I'm also curious about your latches. Are they stock from Boler or aftermarket? And lastly, did you freehand those radius corners? They are 👌🏻
Old 05-15-2024, 05:30 AM   #4
steve67's Avatar
Trailer: '79 Boler
on Ontario
Thank you.
It's not Baltic, a 3/16" birch plywood, but I added strips to the edges to make it look thicker and prevent warping. They've been great for 3 to 4 seasons now.
The hardware is the standard Boler stuff for '79. The Misses spend hours cleaning off the paint of a previous owner.
The corners? Yes, just freehand with a sabre saw.
Old 05-15-2024, 11:34 AM   #5
Thank you.
Nice work! Did you layer the 3/16 birch on top of the edge pieces or is it an inlay. It looked like a solid piece on the front in the photos.
Old 05-15-2024, 12:00 PM   #6
steve67's Avatar
Trailer: '79 Boler
on Ontario
It is supposed to look solid. Strips of the same birch are glued to the inside surface of the doors, a wider strip where the hinges are fastened. Corners and edges are finished after gluing, which is followed by paint or varnish.
Old 05-15-2024, 02:33 PM   #7
Nice! One final question, did you use any joints on the back pieces or are they just butted up against each other and held by glue?
Old 05-15-2024, 02:55 PM   #8
steve67's Avatar
Trailer: '79 Boler
on Ontario
Correct, just glued and butted on the back.
boler
Our Boler Mods: Air, Flooring, Blinds, Backspash, cushion covers... Markz Modifications, Alterations and Updates 10 09-02-2021 04:30 PM
post pics of your Bigfoot mods Alberta Mac Modifications, Alterations and Updates 19 11-22-2020 12:04 PM
Day and Night Blinds, your opinion wanted! Robin G General Chat 9 09-20-2008 08:51 PM
the post reno's pics Legacy Posts Care and Feeding of Molded Fiberglass Trailers 10 06-26-2003 07:27 PM
