Hi,
Recently I ran out of
propane.
Upon replacing the tank, I noticed that the hose leaked.
I put the tank on the other hose, but looks like the hoses were rubbing against the tank all this time, and probably cause the hose to deteriorate.
Initially I thought my rod was setup incorrectly, and thought it needs to be above the tanks, but upon googling I determined that the regulator is too close to the tanks. For now I just moved it up, but it's not an ideal nor a durable setup... I think the regulator has a bracket that is too short, as it should be sticking out more away from the rod. If you look at left tank, you will see rubbing marks (it's been on half a trip). If I move the regulator where it belongs, the hose will start rubbing again.
