Raising a 14"x14" roof vent? - Fiberglass RV
Old 05-29-2012, 04:08 PM   #1
dylanear's Avatar
Trailer: 2001 Scamp 13'
Seems I'm going to need a spacer or riser of some sort to mount my new roof vent/fan without any part of it sticking below the ceiling. My 14x14 vent is between the door and stove and is a highly trafficked spot, I'm used to avoiding it after many months full timing, but it's still really annoying ducking even more than I have to for the low ceiling.
Anyway, my question is, how would you raise a vent 1/2 or a full inch?
I've found this video:
That's the concept, but I'm hoping for a much simpler, cleaner and easier way. I'd really rather not use wood or fiberglass. I'm thinking some simple aluminum rectangular extrusion? Or maybe durable plastic sheet, 1/4" ish thick? I can cut a several layers to make a 14x14 "trim" and silicon them together to get the required thickness?
dylanear is offline   Reply With Quote
Old 05-29-2012, 04:42 PM   #2
dylanear's Avatar
This might work well, it's thick so hard to cut, but I bet I could use the router attachment on my Dremel and cut 1/2" plastic. Might be slow going.
Sheet, HDPE, White, 1/2 In Th, 24 x 24 In - Plastic Sheets, Film, and Flat Stock - Plastics - 3HMN4 : Grainger Industrial Supply
Old 05-29-2012, 07:12 PM   #3
You can make a spacer out of PVC house trim boards from Lowes or Home Depot. It is white, comes in different sizes and is easy to work with. You can screw it and glue it together. If you want your spacer about 1" thick you can trim down the profile off of a piece of PVC brick mold.
Eddie
Old 05-29-2012, 07:25 PM   #4
Trailer: 2004 17 ft Casita Liberty Deluxe and 2001 13 ft Casita Patriot Deluxe
Post a picture of the inside and how the fan sticks down.
If its just the trim ring, it can be cut down so it fits flush with the ceiling.
Glen G is offline   Reply With Quote
Old 05-29-2012, 08:51 PM   #5
dylanear's Avatar
Of my current fan? Or the new one once it's complete?
I'd done a lot of research, it's not just a trim thing. My current fan does have trim I could remove, but there'd still be a metal box for the controls that would stick down and the switches further below that.
The Fantastic Fan, at least the high profile model will only stick down about 1/2 inch, but the opening/closing motor sticks down from there and then there's the manual knob on that. So it's looking like if I want nothing at all protruding than I'll need at least a 2 1/2" lift. But 2" will probably do, with just the knob sticking down some. Perhaps a lower profile replacement knob can be found.
Here's some great install info on the Fantastic Fans.
Fantastic fans pictures Fantastic vents
And an illustration of just how much lift I'll need to clear that knob entirely.
http://www.rvvent.com/images/highprofileautoknob.jpg
Old 05-31-2012, 10:12 AM   #6
Kenny Strong's Avatar
Trailer: 93 "Lil" Bigfoot 13.5'
Utah
look at Lexal in a caulking tube rather than silly cone! Fortunately the opening in my Bigfoot is over the table top. I added 1-1/2" redwood spacer to the interior. All is good.
Kenny Strong is offline   Reply With Quote
Old 05-31-2012, 10:54 AM   #7
Trailer: Bigfoot 17, 1988
Wisconsin
If you haven't altered the fan, consider buying one that doesn't require a spacer. The Maxxfan goes down to roof thickness of 1 and 1/8th inches:
MaxxFan General Overview | Latest
pindraak is offline   Reply With Quote
Old 06-01-2012, 11:00 AM   #8
Wisconsin
Here are pics of the Maxxfan on my Bigfoot. Roof thickness with shower enclosure was about 1.25 inches.
Old 06-01-2012, 11:12 AM   #9
floyd's Avatar
The "plastic wood" spindles used for decks are really good for fabricating the frame for the fantastic fan. It wears like plastic and works like wood.
You can screw into it (best to predrill) to attach the fan. it takes well to sealers etc. You could then cover it with an aluminum extrusion if you like.
Old 06-06-2012, 10:07 PM   #10
Trailer: 1973 trillium
I used Sintra PVC for my spacer in the vent when I put the skylite and reinforced roof in my Trillium. Many suppliers and trade names (troxell, etc..)
Sintra® Board - Rigid PVC Plastic Sheets
PhillyPhixy is offline   Reply With Quote
Old 06-13-2012, 06:13 PM   #11
dylanear's Avatar
I didn't realize I was getting replies to this thread! Not sure how the email notifications are working.
Anyway, good materials info! But I've already started down a course of action. I have a plastics shop in town CNC machining a part out of thick polyurethane sheet, to hopefully precisely match the edge of the fan. Probably going to be about $150, not a cheap part, but I never want to mess with that again once it's installed.
Old 06-14-2012, 09:56 AM   #12
David Tilston's Avatar
I have a 9" vent on my latest Trillium. I will be putting in a 14" Fantastic fan. There is an approximately 1/4" high protrusion around the 9" vent hole that I was considering duplicating on a 14" hole. Maybe, I will go to a 1" protrusion instead. I think doing it in fiberglass makes more sense.
Old 06-14-2012, 12:35 PM   #13
Spanke's Avatar
Trailer: 1978 Trillium 1300
Cumberland, Indiana
I'm going to do the same for my "Trillium". I agree with you on the 1" protrusion and fiberglass especially after reading this thread: http://www.fiberglassrv.com/forums/f...ass-52498.html.
Spanke
Trilliums Rock!
Spanke is offline   Reply With Quote
Old 06-19-2012, 11:28 AM   #14
dylanear's Avatar
I got my parts, they look really good and solid, but it cost a small fortune. Ah, I wanted experience having precise parts made and I got that. $250 added to an already very expensive fan. Ouch, but I think I'll be very happy with the results.
Old 07-01-2012, 01:39 PM   #15
dylanear's Avatar
I'm just not entirely sure how to seal the parts I had fabricated. There's three layers to seal. Fan to first spacer, first to second spacer, spacer to roof. I have the butyl putty tape and was thinking perhaps of using that between the roof and spacer, then silicon between spacers and then not sure if butyl or silicon under the vent.
I'll get some pics posted of my spacers.
Old 07-03-2012, 04:38 PM   #16
dylanear's Avatar
I'm going to posts any updates to this in my new vent install thread.
Here: http://www.fiberglassrv.com/forums/f...-in-52923.html
But I'll put some pics of my spacers here for completeness.
Not in focus, sorry.
Both spacers and the FF in place for the first fitting.
My New "Home Made" Stove Vent - Casita Rob and Linda Modifications, Alterations and Updates 17 02-28-2012 11:25 PM
14" roof vent rabbit Classified Archives 9 09-13-2011 07:53 PM
Boler 9"x9" Roof Vent Wanted Dave Mc Classified Archives 3 06-29-2011 09:17 PM
Replacing ~9" roof vent in Boler Raya Care and Feeding of Molded Fiberglass Trailers 34 12-16-2008 08:01 PM
12"x12" Celing Vent needs replacing Bob H Problem Solving | Owners Helping Owners 1 05-20-2008 08:32 PM
