Remove roof antenna? - Fiberglass RV
Old 06-20-2020, 10:43 AM   #1
Trailer: 1990 Bigfoot B19
Hello again. My B19 has the crank and roof mount, but no antenna. I would not use it even if it was there.
Would it be worth removing it (as a potential leak source down the road) and patch, or just pretend it's still there, and regularly reseal the edges, since I have to go up there and do that to the other openings every year anyway. The seal is sound, and I have no leaks.
I suspect that it might be more trouble than it's worth to remove and patch. It wouldn't be high on the current list of things to do, either way, but just a thought when I was checking out the roof yesterday.
Other possibility - replacing the antenna. I haven't had a good look at the remaining mount. It may or may no be functional anyway. But does any one know where I might source a replacement, if everything was functional, and I decided to go that route?
Deb
1990 Bigfoot B19
Logan Lake, BC, CAN
Deb Mac is offline   Reply With Quote
Old 06-21-2020, 09:43 AM   #2
Trailer: 13' Perris Pacer
"If it ain't broken, don't fix it." And, "Don't fix it until it IS broken!"
mchalewj is offline   Reply With Quote
Old 06-21-2020, 10:32 AM   #3
Sort of where I was going with it!
I'll take a closer look at it when I go up to install the Mini-Mach... see if it looks functional, crank-wise, (anything bent or broken off). If it is functional, then I might look at getting a replacement antenna to mount to it. Or just leave it alone. I don't watch TV when I'm out. Maybe some Netflix if we have good wi-fi, or just some DVD's on the laptop/iPad to the auxiliary monitor.
Deb
1990 Bigfoot B19
Logan Lake, BC, CAN
Old 06-21-2020, 08:44 PM   #4
I'd leave it as is. That way if a future owner wanted to put one on they could easily. Without the antenna the possibility of leaking is less since nothing whips around in the wind. We've not had any trouble on our RV with the antenna but you can tell it moves in the wind.
Old 06-22-2020, 06:41 AM   #5
C&G in FL's Avatar
Trailer: 2015 Escape 5.0TA
Agreed. And sealing it every so often is way less expensive than patching it, especially if you have someone else do the patching.
How easy to remove a roof AC unit from an older 13' scamp? JohnF Problem Solving | Owners Helping Owners 1 09-21-2011 09:23 PM
How to Remove Mold from Roof of Boler? Rusty99 General Chat 8 06-10-2011 02:36 PM
Anyone ever remove their tv antenna? Baj Modifications, Alterations and Updates 5 05-05-2011 10:57 AM
Anyone know what to use to remove black tar from roof? Tim Wood Problem Solving | Owners Helping Owners 12 10-31-2008 09:06 AM
to remove decals or not to remove johnsoba General Chat 15 06-08-2006 12:10 AM
