Removing acorn nuts - Fiberglass RV
Old 06-28-2020, 03:48 PM   #1
Trailer: Uhaul
Removing acorn nuts
How do you remove the acorn nuts throughout the camper? I tried unthreading them but they just rotate about. Do they just pry off? Do i have to replace the rivet when I eventually remove the nut?
Sorry for a simple question.
I'm looking to remove one of the shelves above the side dinette and was surprised the nuts didn't just rotate off.
foofght is offline   Reply With Quote
Old 06-28-2020, 04:41 PM   #2
Removing acorn nuts
The acorn nut is only cosmetic. Even if you get it off, the cabinet will still be held tightly by a bulge in the rivet shaft. That bulge is also what holds the acorn nut in place.
Rivets are removed by drilling off the head from the outside. Be careful not to drill too wide or deep or you may enlarge the hole. You may need a second person on the inside to grip the end to keep it from spinning while you drill.
I’m assuming this is a Scamp or a Casita?
Old 06-28-2020, 05:59 PM   #3
I used to try to tighten the acorn nuts on my Casita until I figured out their only function was cosmetic. I think prying them off or possibly using alligator pliers would remove them.
Dave Fish is offline   Reply With Quote
Old 06-28-2020, 07:19 PM   #4
Originally Posted by Dave Fish View Post
... I think prying them off or possibly using alligator pliers would remove them.
Yes you could probably pull them off. But if they are attached Scamp or Casita style (with a rivet) then there is no reason to do so unless you are removing the rivet. If you want to remove the rivets (to remove a shelf or cabinet), then (as Jon mentioned) drill off the head of the rivet and replace the rivet, or use a SS bolt with nylock washer to replace it, if it still needed. If the fastener is no longer required then just patch the hole.
Old 06-29-2020, 10:21 AM   #5
Radar1's Avatar
The acorn nut is tightened by the expanding end of the rivet as the rivet is installed. It is likely that removing the acorn nut by prying would remove the tension of the rivet, since the rivet may have expanded and snapped up to 1/4" before actually contacting the surface that the acorn nut was resting on, since it snapped when the rivet could no longer expand within the acorn nut.
I would prepare to replace any removed acorn nuts with either a new rivet, or do what I have done and replace any broken rivets with 1/4 x 20 stainless steel screws and nylock nuts. Pro Dec company sells snap cap washers specifically designed for the 1/4" stainless steel screws, and many other sizes also.
We have had a couple acorn nuts just fall off over time, which we replaced with the SS screws.
Sharpsburg, GA
radar1-scamping.blogspot.com
Old 06-29-2020, 10:51 AM   #6
steve67's Avatar
Trailer: '79 Boler
on Ontario
Another member was asking the same question... Some answers here:
https://www.fiberglassrv.com/forums/...zes-92682.html
steve67 is offline   Reply With Quote
Old 06-30-2020, 03:55 PM   #7
Trailer: Uhaul
Thanks all.
I'm now wondering about rivets and stainless screw/bolts and washers, but will search around to see what the thoughts are.
Old 06-30-2020, 05:36 PM   #8
steve67's Avatar
Trailer: '79 Boler
on Ontario
These are the fasteners I used to replace all the pop rivet to acorn nuts. The machine screws are 10-32UNF x 1" (length allowing for shortening when needed. All pieces are stainless steel to deal with condensation.
The acorn nuts do not need to be too tight, so some Locktite could be useful.
vin
Rivets, Acorn nuts, Rivnuts etc. Dan B Care and Feeding of Molded Fiberglass Trailers 45 11-22-2016 08:21 AM
rivets, caps, washers and acorn nuts beardrum Care and Feeding of Molded Fiberglass Trailers 30 09-12-2013 09:48 AM
acorn nuts sfoss Modifications, Alterations and Updates 4 03-03-2012 05:23 PM
Scamp Acorn Nuts Parker Buckley Problem Solving | Owners Helping Owners 8 10-14-2009 08:08 PM
Rivets and Acorn Nuts Steve L. Modifications, Alterations and Updates 6 11-16-2005 09:36 PM
