Renovating a 71 Eco - Page 2 - Fiberglass RV
Old 08-02-2019, 02:27 PM   #21
Trailer: Eco
Kansas
Fast-Forward through a lot of cleaning and painting (covered lightly previously) and this is where we're at inside... lots of gloss white everywhere.
My '71 Eco Restoration Gallery
Baxter is offline   Reply With Quote
Old 08-02-2019, 02:31 PM   #22
Trailer: Eco
Kansas
And here you can see the before-and-after from it's trip to the local trailer repair place this week.
Aside from having that angle-iron contraption removed from the rear, it's now sitting on brand new bearings and tires.
While it was there I had them inspect the frame stem to stern (no problems) and take a good look at the axle, which amazingly checked out good too.
Old 08-02-2019, 02:36 PM   #23
Trailer: Eco
Kansas
I also ran it through the car wash on the way home. it's still filthy, but less so.
Next up: Painting and cleaning will commence, but the next large-ish project is the windows. I don't really want to tackle them myself -- replacing windows on MGs and VWs back in the day kinda soured me on that sort of work, but so far I haven't found a Kansas City-area place that wants to touch it. I still have some feelers out, though. We'll see.
I also need to install the new hinge pins I bought, hoping that'll help the door sag. I think so. The current ones are pretty shabby.
I've also got some seals and taillights and I can't remember what all coming in the mail to put on.
Oh, and picking up an AC now that I know how I want to do it, as soon as they go on sale.
Old 08-03-2019, 05:18 PM   #24
Trailer: Eco
Kansas
Tackled the hinges last night. Short, easy job. As you can see in the before pic, a stack of washers was ďgood enoughĒ. There was no ball at all.
Itís hard to tell in the pic, but both of the old pins were bent.
Much better after a few minutes putting the new one in.
B567B8D4-6C46-4101-A656-5557904CEDA2.jpg   816169C4-0978-47E3-B245-DF6288CF0836.jpg
Old 08-03-2019, 05:21 PM   #25
Trailer: Eco
Kansas
Unfortunately thereís still a lousy fit.
Miraculously itís pretty tight at the bottom but itís definitely sagging.
Is there any adjustment in the hinges? It doesnít look like it, but maybe?
Iím a little stumped. The frame checks out as solid.
1512557C-F61D-40A0-9DFF-9A900956C62D.jpg   CB1A87F2-AABE-4794-B0FD-B96B5CC102C2.jpg
Old 08-04-2019, 08:45 AM   #26
FRED SMAILES's Avatar
Trailer: 13 ft Boler
Kootenay's of BC
The shell has probably shifted a bit over the years changing the shape of the opening.
Try jacking up the roof in that area a bit to see what happens. Use a 2x4 against the roof to spread the pressure.
Fred
FRED SMAILES is offline   Reply With Quote
Old 08-05-2019, 07:15 AM   #27
Trailer: Eco
Kansas
This weekend I got a little caught up in might-as-wells. It all started with taking the moldy Dometic add-a-room off. Once it was off, the general state of filth was even more obvious. Normally when I bring a new project home the first order of business is giving it a good bath. This time, events conspired to keep that from happening, so here we are a month later and I still haven't given it a good exterior cleaning.
So three hours of scrubbing later, I finally had most of the grime off. The trailer is noticeably less brown and more red now
With it finally well-scrubbed, I got it in my head I might as well go ahead and put the intended white paint up top. So I did. Well, the first couple of coats at least. It'll need at least one more, probably two. But I think I'm committed now.
Old 08-12-2019, 07:51 AM   #28
Trailer: Eco
Kansas
Last week I started test-fitting the new countertop, and began putting in the flooring.
Old 08-12-2019, 07:53 AM   #29
Trailer: Eco
Kansas
And this weekend painting re-commenced. I put on another coat of white and started on the red, laying down 3 or 4 coats. It needs at least one more, but it's starting to come together.
Old 08-12-2019, 08:56 PM   #30
Trailer: Eco
Kansas
By the way, thatís a rustoleum roller paint job.
Old 08-12-2019, 10:07 PM   #31
Trailer: '82 Burro 13'
Northern VA
Beautiful
1982 13' Burro
Burro Renovation
Dan-NS27 is offline   Reply With Quote
Old 08-12-2019, 10:25 PM   #32
Trailer: In the market
Wouldnít have believed it if you didnít show the roller and tray in the second photo.
Nigel
NigelW is offline   Reply With Quote
Old 08-13-2019, 05:37 AM   #33
WaltP's Avatar
Trailer: 2017 Escape 17B
SW Virginia
Looking very nice. I hope to see it at a Bolerama soon.
Walt
Old 08-21-2019, 07:25 AM   #34
Trailer: Eco
Kansas
Haven't updated in awhile, but I've stayed busy.
The two biggest items are the new vinyl plank click-lock flooring....
Old 08-21-2019, 07:27 AM   #35
Trailer: Eco
Kansas
And the AC install under the front bunk (which I've detailed in greater depth elsewhere.
Old 08-21-2019, 07:28 AM   #36
Trailer: Eco
Kansas
And I've been busy with lots of little trim bits, like molding around the floor pieces, around the AC, new trim-lock around the front door, and so on (and on).
And I finally put up the new cabinet doors!
Next up is the sink, countertop and backsplash, which are *almost* ready. I'm including a shot of the rough-cut test fitting here.
Old 08-21-2019, 07:34 AM   #37
Trailer: Eco
Kansas
These are a bit out of sequence, but my spouse took them, and she's a much better photographer than I am. So I'm sharing them.
Old 08-21-2019, 07:35 AM   #38
WaltP's Avatar
SW Virginia
Wow! Lots of progress and looking great, especially the floor.
Thanks for sharing.
Walt
Old 08-21-2019, 07:39 AM   #39
Northern VA
Really like the flooring. Everything is looking good.
1982 13' Burro
Burro Renovation
Old 08-21-2019, 07:52 AM   #40
Trailer: Eco
Kansas
Thanks for the kind words. Putting it all back together bit is pretty satisfying. It's really coming together nicely, and I think we're still on track for a shakedown trip over Memorial Day weekend. It won't be *done*, but it should be usable.
Hopefully, I should get the countertop in and the sink plumbed in this week, and the foam cut for the cushions.
I keep knocking off items from the to-do list, then adding more items back onto it.
boler
Renovating the Madhouse (1975 Boler full renovation) Joe MN Modifications, Alterations and Updates 50 09-15-2015 07:28 AM
Fire creates it's own eco system Gina D. Camping, Campout Reports 10 11-25-2007 05:33 PM
We're already eco CharlynnT General Chat 11 05-22-2007 03:37 PM
ECO issues Matt O'Bryan Problem Solving | Owners Helping Owners 10 02-20-2006 12:30 PM
ECO trailer - Aurora NE Legacy Posts Care and Feeding of Molded Fiberglass Trailers 11 01-06-2003 03:03 PM
» Trailer Showcase
Nadine
srndpte
SCAMP
lables
