Nicely done!
Since you don't often dry glamp, that should serve you very well. And as you indicated, if you do dry glamp, a
generator is the best means to power a compressor
refrigerator and an air conditioner if you have one. We would also highly recommend using a
propane generator. We personally use a highly reliable, lightweight and quiet Honda EU2200i generator that was modified with a Hutch Mountain
propane conversion kit. Our generator directly receives
propane from our trailer dual 20 pound propane tanks using a MB Sturgis Quick Connect Sturgi-Stay placed between the tanks and trailer propane regulator and using various lengths of high pressure propane hose that can be connected together to locate the generator as desired.
https://mbsturgis.com/products/5th-w...t-sturgi-stay/
Gasoline generator exhaust smells awful, gasoline goes bad and gasoline gums up carburetors. Using propane doesn't create these issues and also avoids the hassle of sourcing/storing gasoline. And if you dry glamp, one will always need to source propane anyhow for one's propane absorption
refrigerator,
furnace and stove.
More photos and details of this
Casita trailer modification and all our other many
Casita trailer modifications may be found by Googling our trailer name if interested.
Gayle & Bob
"Los Gatos Casita"
