Replacing Scamp 13" windows how-to - Fiberglass RV
Old 04-25-2021, 03:42 PM   #1
Trailer: Scamp 13 ft
Question Replacing Scamp 13" windows how-to
I've searched quite a lot for a tutorial on removing and replacing the windows in our 2005 Scamp 13". I'm not yet sure that I need to do that but if I do I want to know how. They leak and that's likely because the soft parts have hardened over time. The weep holes and the channels are clean but I still get leaks at times. Anyway, if someone knows where there's a good how-to in written, photo, or video form please let me know, and thank you.
Mike J. L. is offline   Reply With Quote
Old 04-25-2021, 06:24 PM   #2
Name: You can't call me Al
Massachusetts
There are three different kinds of windows on each Scamp 13'.
Also, there are at least two different kinds of side windows that have been used over the years.
I've changes two out of the three so far on my 1977.
Which ones would you like more information on?
Posting a photo would also help.
AlanKilian is offline   Reply With Quote
Old 04-25-2021, 07:27 PM   #3
They’re the standard sliders, 2 side & 1 rear, for a 2005 Scamp. One 18 x 42 and two 18 x 24. They’re available on this page from Scamp: https://www.scamptrailers.com/product-category/windows
Thank you
Old 04-25-2021, 07:39 PM   #4
Massachusetts
OK, those are too new to have been on my 1977 so I don't have any experience, sorry about that.
Old 04-25-2021, 08:17 PM   #5
Thank you for asking.
Old 04-26-2021, 09:57 AM   #6
neauone's Avatar
Easy fix
There is a window sealant that is a puffy and comes in a thin roll. Remove the window apply the puffy, it has like a 25 year life expectancy. I had to drill out the rivets and replaced them with stainless steel screws and locking nuts. Make sure any rubber gaskets are checked.
Also check rubber around the interior of the windows and structure cracks in case water is entering around the window fiberglass
neauone is offline   Reply With Quote
Old 04-26-2021, 09:58 AM   #7
neauone's Avatar
Not puffy
Puddy
Old 04-26-2021, 10:01 AM   #8
Massachusetts
Or Putty.
https://www.amazon.com/Colormetrics-...9452937&sr=8-1
Old 04-26-2021, 10:01 AM   #9
Thank you
Old 04-26-2021, 10:18 AM   #10
neauone's Avatar
Yup
Originally Posted by AlanKilian View Post
Thatís the stuff Butyl tape, check eBay sometimes you can save money
Old 04-26-2021, 10:42 AM   #11
I have a roll of butyl tape. I used some around the roof vents. It seems to work well to seal leaks.
Old 05-05-2021, 10:13 AM   #12
Remove frame from inside (screws not rivets) mine is 05 as well. Plan on at least a half day cleaning frames used acetone, goof off, extra. Only do ONE at a time as frames provide some support to the body replace the butyl tape and use NO SILICONE!
barrry smithe is offline   Reply With Quote
Old 05-05-2021, 10:26 AM   #13
thank you
scamp, windows
"Camping" vs. "Traveling" Timber Wolf General Chat 54 08-07-2016 12:32 PM
Windows, windows, windows Matt4483 Problem Solving | Owners Helping Owners 24 02-10-2016 01:50 PM
Replacing the rectangle aluminum windows with modern rounded corner windows Evergreen Modifications, Alterations and Updates 16 10-29-2010 12:09 PM
Some "before" and "after" shots..... Don & Viv Modifications, Alterations and Updates 13 07-29-2010 04:52 PM
