Requesting feedback on refinishing scamp cabinets - Fiberglass RV
Old 04-06-2020, 06:53 PM   #1
Hello,
I am in the process of renovating my '73 Scamp. I've always been bothered by how dingy the cabinetry and closet look. I've attached a photo below. Has anyone had experience refinishing or painting this surface? I'm not sure if it is fiberglass as well? Any feedback on the process and how well it has held up would be much appreciated!
Thanks in advance!
Ashlee
ABECK7 is offline   Reply With Quote
Old 04-06-2020, 08:17 PM   #2
Trailer: 2010 Little Joe / 2010 2 Dr Jeep Wrangler
Originally Posted by ABECK7 View Post
Hello,
Thanks in advance!
Ashlee
The cabinets look like fiberglass ( that is standard)
However the doors are pressed wood.... easy to repaint if you arenít up to making new doors
Old 04-07-2020, 04:48 AM   #3
South Carolina
my casita came with pressed wood doors which i replaced with 1/2" plywood stained with golden oak and sealed with polyurethane. i think they look a lot better than those wood grain wallpaper sawdust doors and weigh a lot less....
p@
patrick crawford is offline   Reply With Quote
Old 04-07-2020, 12:11 PM   #4
If it is the fiberglass portion, clean and polish just like you would do with the outside. If it is the doors, paint. Lots of threads on both.
The fiberglass portion is basically maintenance free, eventually clean and polish. My 1977 Trillium interior fiberglass is as original. I did paint the fake wood doors and replaced some broken ones.
Old 04-08-2020, 07:27 PM   #5
Thanks! I should clarify, I've replaced the pressed wood doors already. I am referring to the fiberglass portion.
Old 04-08-2020, 07:30 PM   #6
Thanks Bill. I've cleaned and washed the fiberglass portion thoroughly but it still looks terrible. I would like to refinish and paint it if possible but I'm afraid it will chip.
Old 04-08-2020, 07:32 PM   #7
p@
Those look great! I replaced my pressed wood doors with pine and applied stain and poly.
Old 04-08-2020, 07:53 PM   #8
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
Try using a rubbing compound made for fiberglass, like such used on fiberglass boats. They come in various abrasive compounds, so try using the least abrasive first, and if that doesnít work, use the other followed by the less abrasive one. Follow up with a good wax for fiberglass. Good luck.
Dave & Paula
Old 04-08-2020, 09:21 PM   #9
I painted the fiberglass cabinets on my 73 boler after having patched the many holes in them. Lightly sanded them, used Bullseye 123 to prime and used a Benjamin Moore satin on top. It's held up really well for the last year. I know some people have gone with marine enamels for a topcoat which for sure would hold up well but I really didn't want a gloss finish. Actually full disclosure - Used the same for the ensolite.
bobdobqb is offline   Reply With Quote
Old 04-09-2020, 06:51 AM   #10
If it has a lot of patches, then paint is a good option. Otherwise, I would read up on Marine Polishes, there is a good thread on the forum, 3M makes a lot of them.
I personally like the original gelcoat inside my 1977 Trillium. I think it looks good. The dark vinyl covered doors were hideous. By painting them, I think I really lightened up the inside of the trailer. I could lighten it further if I did something on the original curtains and cushion fabric. But I like keeping mine basically original (minus the hideous vinyl fake wood doors). Dumping the original shag carpet helped too! I also replaced all the beat up original lighting with LED fixtures. Not only did it greatly reduce the power usage in my trailer (about 90% compared to incandescent), but I was able to add more fixtures. I replaced several single lights with doubles, which I can have completely off, run one, or run both.
1977 Trillium Painted Cabinet Doors by wrk101, on Flickr
1977 Trillium 1300 by wrk101, on Flickr
Old 04-15-2020, 11:56 AM   #11
Name: Steve and Rosemary
Utah
I don't know about painting the fiberglass inside -- I like how it looks and if it was dingy, I'd probably lean towards trying to fix it like fiberglass.
HOWEVER, if you're going to paint it, I'd consider using a "cabinet" paint as in a house kitchen. These paints tend to create a somewhat hard "shell" and a few of my friends can attest to their durability in well-used kitchens. I'm not sure exactly what product they used, but I'm confident it was Sherwin-Williams. You might contact them and explain what you're trying to do.
Whatever you do, good luck and happy remodeling!!
LUCINDA 1989 Bigfoot 5th Wheel | Steve, Rosemary, Maude Pod & Tripawd Hope
'Glass trips: Moab 03/10 * The Swell 5/26/11 * Antelope Island 12/21/11 * Strawberry Res 6/12 * Whitney Res 6/14 * Uintahs 7/15 * East Fork of Black's 6/16 * St Mary-Ennis-Lava 6/18
Steve and Rosemary is offline   Reply With Quote
Old 04-15-2020, 02:02 PM   #12
Name: Kate & George
Trailer: Boler 1300
AB
Great-looking cabinets, lights and support column!
Kate W is offline   Reply With Quote
Old 04-15-2020, 02:52 PM   #13
Hidalga's Avatar
Trailer: Modified 13' Scamp
Full-Timer
Hello,
I am in the process of renovating my '73 Scamp. I've always been bothered by how dingy the cabinetry and closet look...Any feedback on the process and how well it has held up would be much appreciated!
Thanks in advance!
Ashlee
Hi Ashlee,
Before you paint, try a polish called Flitz. Available in various sizes and a liquid or paste. It's often advertised as a metal polish, but works wonders on fiberglass. I prefer the paste, and a little goes a long way so don't get too sticker shocked.
If there is any life left in the fiberglass, Flitz with some elbow grease will make it shine and brighten up.
RV Compass: Unconventional Rallies for Independent RVers
Publisher of The Roost - the monthly e-newsletter that reports mass flockings of Egg trailer enthusiasts
Hidalga is offline   Reply With Quote
refinishing a '69 scamp Timothy Campbell Care and Feeding of Molded Fiberglass Trailers 3 04-26-2019 08:46 AM
Refinishing Trillium Stovetop Alex C Problem Solving | Owners Helping Owners 14 01-19-2017 05:31 AM
Scamp 13 Refinishing jcassady Modifications, Alterations and Updates 9 06-04-2014 02:50 PM
Refinishing the Interior Rick Harmer Problem Solving | Owners Helping Owners 4 11-28-2009 06:40 PM
refinishing the interior of the captain Bryan B. Care and Feeding of Molded Fiberglass Trailers 17 04-13-2009 05:03 PM
