Roof vent fan upgrade - Fiberglass RV
Old 05-03-2017, 09:52 PM   #1
Name: Billy Sharpstick
Trailer: Scamp 13 - 2005
Reolacing the old roof vent fan, Fantastic 4000R. Apparently the second one. Roof has two sets of holes all over the place. About half of them are where the new Maxxair installation screws need to go.
Plan:
1. Old chisel to remove most of old silicone.
2. Use silicone remover and wire wheel to clean up the rest of it.
3. Drill out old screw holes and fill back up with JB Weld epoxy to drill fresh screw holes into.
4. Mount new trim with butyl tape.
(Maxxfan 4301K exhaust only, no remote, rainshield builtin, 900cfm)
sharpstick is offline   Reply With Quote
Old 05-04-2017, 03:03 AM   #2
Raz
Raz's Avatar
Vermont
Plan:
If it matters, I believe the old fantastic fans came with a life time warranty that is still honored.
Old 05-04-2017, 06:34 AM   #3
roof fan replacement
The old one still worked. It was just old. (mfg date 2003) It is an older style motor that I suspect was less powerful and efficient. (It is a tall cylinder instead of the newer pancake ones). I didn't even realize it was a Fantastic until I got the new one and removed the old one. It didn't seem that powerful.
Old 05-04-2017, 09:46 AM   #4
Raz
Raz's Avatar
Vermont
Yeah, me too.
I went through the same exercise last summer when I replaced a Max fan with a Fantastic Fan. The hole had to be enlarged as the Fantastic fan was about 1/8" larger in both directions. But no silicon to remove, I don't envy you. Good luck with the project. Raz
Old 05-06-2017, 04:32 PM   #5
When you install your's does it sit flush to the inside of the trailer? I had to build a spacer that fit on top of my trailer to do so. Also, maybe I was a bit lazy, but I had a few extra left over screw holes too, but with the butyl tape to seal everything up, I didn't bother filling them with anything.
TimR is offline   Reply With Quote
Makeshift Roof Vent Fan Brentshirt Modifications, Alterations and Updates 6 08-14-2015 01:42 PM
Installing Maxx Air Fan Mate 850 Vent Cover Over Fantastic Fan CampyTime Modifications, Alterations and Updates 7 10-10-2013 10:43 AM
Fan vent that is flush with the roof? Patrick J Modifications, Alterations and Updates 1 09-18-2010 10:57 AM
To Roof Vent, Or Not To Roof Vent Frederick L. Simson Problem Solving | Owners Helping Owners 5 02-22-2009 05:41 PM
Replace roof vent on Scamp with fan? Conrad S. Care and Feeding of Molded Fiberglass Trailers 2 05-13-2008 06:45 PM
