Originally Posted by Ridgerunner
Nice job Floyd.
It probably wound make more sense to remove the 11” x 11” and do what you did and put it a 14”.
I’m sure it would move a lot mor air than an 11”.
Looks like your frame comes down about a 1 1/2”.
Did you cut your hole from the inside or outside?
I basically cut two sides + a couple inches to extend the line of the starboard side.
If I remember correctly I cut the elephant hide from the inside with a razor knife after drilling to mark the corners, then cut the
fiberglass from outside making straight cuts from each corner hole.
I made the "wood" frame from plastic handrail spindles made of that decking material. It is waterproof.It works well but should be pre-drilled for the fasteners and glued on the corners.Also pre-drill for the four screws which hold the escutcheon.
Also in this case I used the "frame" to fasten the fan down through the roof from above.
