Thanks for remembering my project. It has turned into a several-year effort as I discovered more defects and limitations that need correction. For starters, virtually every improvement of Little House Customs and ideas appearing on this blog that have proven themselves in the field have been incorporated.
As an airline pilot, I admit to being spoiled and used to functional products tested to the highest standard. To be clear, it has two easy-to-state, yet challenging-to-achieve goals:
1. Four-season capability to eliminate the loss of use "winterizing" nightmare.
2. Unimproved road navigation capability to open up 185,000 miles of unimproved USA forest service roads.
Here is a BRIEF taste of completed projects:
An entirely new frame that is frame-welded onto the existing frame, vacuum-sealed and corrosion-proofed to provide the durability, strength, and insulation needed to survive the CONSTANT POUNDING, FLYING DEBRIS, UNDERCARRIAGE IMPACTS and WATER EXPOSURE of unimproved roads. Shock absorber suspension features sealed maintenance-free bearings for 100,000 miles. The new unit will thrive wallowing in (the mud, the blood and the beer". No more popped rivets, window and door leaks/jams from shell stress due to a twisting frame.
Double-pane, glazed
windows throughout and 4" insulated floor. Our temperature range target is -20F to +130F. which will accommodate 98% of real-world temperature extremes in America and Europe. Comfortable camping in extreme temperatures and remote areas is the goal.
Rear window
awning designed with 3-D printing technology to accept a full span
awning to completely shade the large rear window.
Toilet converted to composting after careful testing. The blackwater tank has been converted to freshwater. Pressure water capacity is now +40 gallons in two separate tanks.
All
propane open flame appliances replaced with
electrical ones so that it operates underway and parked from onboard power or from the tow vehicle pretty much like the climate-control system in a car - set it and forget it. No more babysitting the batteries. A CAN network runs throughout the trailer to coordinate appliances.
I've hired an independent lab to certify the operation of critical
electrical components to -20F. So far, limited testing shows the shell easily maintains 70F internal temperature with OAT of 108F in the blazing sun.
To achieve these results, parts contributions from vendors in 5 countries - some of them custom fabricated - have been incorporated.
Our present hangup is the onboard power pack support electronics which has worked in prototype and failed in production testing. Back to the drawing board for the third time.
I've assigned an unlimited budget to the project which is now estimated to double the all-in cost from $17,000 to $34,000 (while quadrupling the performance).
I'm anticipating another six months before we start on-road testing. (Aviators LOVE testing.) Our target speed is 100 mph and 8% road grade. More details will be published when available. Any improvement suggestions gratefully accepted.
