The wire goes into the bottom of the back splash at the rear end of the kitchen. It is drilled into the closed gap between the back splash and the outer shell. The best way to get to this spot is to remove the
furnace. It should be noted that this is not easy. The telescoping exhaust / combustion air vent is usually rusted, and no longer telescopes. Removing the
furnace frequently destroys it. In the upper cabinet, the gap is open, but covered by Ensolite.
The pictures below are from two trailers. The under the counter picture is from 13-
609 a 1300, and the upper cabinet picture is from 45-11
00036 a 4500, with no 110 above the sink, but you get the idea.
