12-23-2017, 09:20 PM
Trailer: C
Iowa
Safe to mount a Casita on a flat-bed truck?
Would a Casita suffer weird structural damage from being mounted on a flat-bed truck? I plan to eventually mount my Casita on a truck, and create an RV out of it. I assume I could take the wheels off, and have mounts welded to the bed of the truck that simulated wheels, so the Casitas axle would be mounted on the truck.
12-23-2017, 09:40 PM
Trailer: 1987 Casita 16
Illinois
You might not even need that big of a truck. Check with some of the larger van manufactures -- sometimes you can get one without a lot behind the front two seats. I have seem some truck being trucks across the country where only the cab is on them, and the frame could easily be mounted to the frame of the camper.
12-23-2017, 10:17 PM
Arkansas
Have to ask: why would you want to?
12-24-2017, 04:06 PM
Trailer: C
Iowa
To make it easier to move around, and to carry more water for off-grid use. I currently have a pickup to pull it, and maybe I will just put a 2nd freshwater tank in the back of my truck - and just fill it when I have parked the Casita.
I like the idea of a driveable RV, but I've never seen one built as well as my Casita. So I was thinking of marrying a really good drive-train with a really good fiberglass trailer.
Another option is to get a large cargo van as my tow-vehicle, and convert the inside as a mini-RV. Then I just take the van when I was doing short travels, and use the Casita as a less mobile basecamp.
Lots of options, now that I'm use to living in 84 sqft.
12-24-2017, 04:12 PM
Virginia
Would more than likely be stronger than a trailer. Frame bolted to frame or flat bed. Go for it!
12-24-2017, 05:14 PM
Trailer: 93 Burro 17 ft
That would make it easier to pull a boat, too!
12-25-2017, 05:46 PM
Trailer: in the market
We are in the process of switching from a class A to an Escape 19. One of the reasons is to make us more nimble. We bought a Nissan NV 3500 passanger van to use as a tow vehicle. You could get a cargo version as well. We wanted some extra seats. Our original intent was to pull the last 2 rows of seats out and build in storage but we found just pulling the last row gave us plenty of room. IMO, this gives you a lot of flexibility. We'll be putting this to the test in April when we pick up the trailer at the factory and drive it to the East coast.
12-25-2017, 06:06 PM
Trailer: Roamer 1
Smith Valley, Nevada
If you retain the trailer axle, you'll have to retain the hitch too. Maybe better to remove the axles and the tongue, then bolt the frame down to the bed of the truck. Then pull some leaves out of the rear springs to give a more compliant ride with the load that is then lower than what the truck was designed for. This will reduce the stress on the trailer body.
The Isuzu NPR trucks can be configured in many different wheelbases which might help you set it up. They can have beds in either 7' or 8' widths. They are also low powered and rough riding, but very reliable.
Maybe you could turn the wheel wells into cabinets with outside doors.
12-25-2017, 07:07 PM
Trailer: C
Iowa
I like those Escapes, they look well built. I like the straight-lines, easier to skirt than my Casita. I had also considered a Nissan, I like their boxy look too, lol.
12-25-2017, 07:14 PM
Trailer: C
Iowa
I like those Isuzu NPRs, they look perfect. There are also used military vehicles, but I know much about them. They seem to cost $4k-$8k. I'm sure the parts are not cheap.
12-26-2017, 08:42 AM
Most people that do this are looking for an extreme backcountry rig. It will be noisy, cumbersome, and fuel-hungry on the highway. If that's what you want, then fine.
If not, then a van plus towable seems like a better option.
12-26-2017, 10:09 AM
Trailer: Casita Spirit Deluxe 17' 2012
I think a van to tow the Casita is a better idea, but if you were to mount the Casita to a flat bed, I would remove the axle and suspension from the Casita, and secure the frame of the Casita to the truck bed.
12-26-2017, 10:44 AM
Trailer: Casita 16ft.
Or remove the frame and mount the trailer body to a home built frame mounted to a the truck. It wouldn't take much. Heck, I think you could even use wood. That way you can put your original frame in storage for reuse in case you later change your mind.
12-28-2017, 12:08 PM
Trailer: Sprinter 'til I buy
Denver, CO
A tow van might be simplest. There are several good choices in Ford, Dodge, Nissan, & Sprinter. I know that Sprinter offers cab only enclosed cab versions, and open-back cab versions, used in walk-through RVs. You just might find a deal on a used one that would ride and provide better mpg than an Isuzu mid-size.
Come to think of it, pick up beds are often removed to make utility truck cabinets. A Casita might fit well on a long bed chassis. Or not.
