My Bigfoot is a 1988 Lil Bigfoot, so I don’t have measurements for you. But my rear cabinet was sagging drastically on one side.
In my trailer, there were wooden blocks/cleats fiberglassed to the shell inside the cabinet. The bottom frame of the cabinet is screwed into these cleats. (This is one of many things I like about the Bigfoot line… NO RIVETS going through the outside shell.) In my case, the screws had completely missed the cleat on that side.
It took some powerhouse methods from the bottom to get the cabinet up to the proper level, and then we were able to screw it in securely.
Perhaps check inside your cabinet (there may be a false bottom you can remove from inside to get a better look) to see if you have helpful cleats you can reattach to? Rather than measurements you might merely be seeking a level cabinet.
You are lucky on that score, as your 17 is much less ROUND than my 13. There is no real LEVEL inside this trailer
, we just do the best we can.
Somewhere in this forum there are my photos of of the sagging cabinet… and I think some descriptions of what we did, if that might help.
Since you have been working on your roof, you may have encountered cone-shaped nipple looking things sealed with some material… I have at least four of these up there but there may be six. It’s been a while since I looked at them. These are some kind of through the shell attachment for the cabinets below. Not rivets… something more robust. Not pretty, but water tight and secure so far.
Let us know how you go!
