Scamp 5th wheel landing gear idea - Fiberglass RV
Old 07-13-2020, 12:02 PM   #1
Trailer: Escape
We have a 1991 Scamp 5th wheel on which I replaced the leveling jacks with the scissor type jack for additional lift. I use a battery impact wrench to adjust these as it is much faster and easier than using a hand crank. This has given me the idea to cut off a landing gear removable crank handle and weld a bolt on the end, then use my impact wrench on it as well. I wonder if the internal gears of the factory landing gear would not be harmed with the impact type of use. Has anyone done this? Opinions? I just think this to be so much more economical than replacing the landing gear with new electric upgrade.
George n Mary is offline   Reply With Quote
Old 07-13-2020, 01:35 PM   #2
AC0GV's Avatar
Wisconsin
Stabilizing jacks
Originally Posted by George n Mary View Post
We have a 1991 Scamp 5th wheel on which I replaced the leveling jacks with the scissor type jack for additional lift. I use a battery impact wrench to adjust these as it is much faster and easier than using a hand crank. Has anyone done this? Opinions? I just think this to be so much more economical than replacing the landing gear with new electric upgrade.
The jacks on the back or for stabilizing not leveling. Level side to side with blocking under the tires and front to back with the landing gear. Yes, others use a drill (not impact) to drop the landing gear. (But always have a backup plan for when the drill dies.)
AC0GV is offline   Reply With Quote
Old 07-14-2020, 09:42 AM   #3
Trailer: Boler
Thumbs up Welded on nuts to scissor jacks
Did that modification to my scissor jacks on my 76 Boler years ago and it works great. Level the trailer first then use the jacks to stabilize.
Steve Stresman is offline   Reply With Quote
Old 07-14-2020, 01:49 PM   #4
Trailer: Scamp 5th wheel
MB
I used an 18 volt Milwaukee drill on the landing gear crank; bought another crank handle, cut the handle off and put it in the chuck. Worked great. But I've since added a motor drive to the landing gear which I bought on Amazon for $150 cdn. Works even better.
Mike255 is offline   Reply With Quote
scamp
Motor for 5th wheel landing legs? gihuff Problem Solving | Owners Helping Owners 15 07-10-2014 08:40 AM
Maximum Gear Load in 2012 Scamp 13? CampyTime Towing, Hitching, Axles and Running Gear 11 03-30-2014 06:42 PM
Convert landing gear to electric on Scamp 5er Steve Hammel Problem Solving | Owners Helping Owners 11 09-12-2013 05:56 PM
19 ft 5er Scamp - add electric motor to landing gear? shooter_41 Problem Solving | Owners Helping Owners 14 01-04-2013 05:28 PM
Scamp 5th Wheel front landing gear (Friday the 13th was bad) Gail Shook Problem Solving | Owners Helping Owners 8 07-31-2012 04:33 PM
