Scamp specific stabilizer jack kit - Fiberglass RV
Old 08-22-2021, 06:37 AM   #1
Trailer: Scamp 1995 19'
Has anyone installed the scissor jacks from Scamp?
Do they have to be welded on? I assume they go where the original jacks were bolted on to the rear bumper? Are they easy to use a drill with? Do they feel flimsy?
I know they are not for use as a jack and don't wish to do so, but I absolutely need them to do a good job of stabilizing the back end of my 19' 5th wheel.
I saw references to the BAL brand jacks which look waaay more heavy duty. If anyone has experience with installing those onto the scamp please do chime in as well, preferably with price paid.
Thanks!
jwcolby123 is offline   Reply With Quote
Old 08-22-2021, 07:09 AM   #2
Not on the bumper. Bumper is for stabilization only, not lifting. Install on the frame under the rear dinette. That’s where Scamp now installs the BAL stabilizers. They are strong enough to lift the trailer to change a tire or assist with leveling.
Others will have to supply mounting details. I still have the old bumper mounted Atwood stabilizers.
Old 09-21-2021, 05:38 PM   #3
They don’t go where the original ones go on the rear bumper. I had a tube welded between the frame rails Mabe a foot forward. I had a hitch receiver welded to the back bumper and the cross member. We used BAL. c type stabilizer jacks , those appear to be same as OEM . We screwed the jacks to the cross member. I hoped it would stop movement of the floor when we move around at night. It didn’t help much . Next plan is to install BAL lock-arm stabilizer bars to one leg of front landing gear.
John 1959 is offline   Reply With Quote
Old 09-21-2021, 11:42 PM   #4
interesting
My old fashioned type stabilize the coach a lot, almost entirely. The only reason I am going to the scissors is that they look much easier to drop down.
What is the c type?
JWColby EAAT
Exalted Arbiter of Anal Tripe
Old 09-22-2021, 06:19 AM   #5
I’m confused now. Which are we talking about?
Scamp old-style Atwood stabilizers (bumper mount)
Scamp new-style BAL stabilizer jack (frame mount under cabin)
Scissors-style stabilizer jack (not used by Scamp)
Old 09-22-2021, 06:48 AM   #6
[QUOTE=jwcolby123;826056]My old fashioned type stabilize the coach a lot, almost entirely. The only reason I am going to the scissors is that they look much easier to drop down.
The old style Atwoods that Jon shows drop down easy, you just push in on the top end to release them and they drop right down. Folding them back up takes a little more effort.
Old 09-22-2021, 07:20 AM   #7
For me releasing them from behind the bumper to swing down is the hardest part because you have to reach around the bumper, grab the jack blind, and give a firm tug sideways. Floyd welded little handles on his to give something to grab besides the body of the jack.
BAL and scissors jacks are more capable. They can be used to lift and support the trailer for changing a tire as well as campsite leveling (but not for working under the trailer). However both require a tool to screw up and down. The BAL is better with the optional foot pads (not shown).
I haven’t found a compelling reason to change. The Atwoods are simple and tool-free.
Old 09-22-2021, 10:27 AM   #8
[QUOTE=Jon in AZ;826065]For me releasing them from behind the bumper to swing down is the hardest part because you have to reach around the bumper, grab the jack blind, and give a firm tug sideways.
On our Casita I can get at the top of the Atwood stabilizer when they are folded up, so I just push on it with the tool and they drop right down. As far as lifting a trailer to change a tire with any type of stabilizer, I don't think that is a good idea as you can distort the frame. Better to jack near the axle. But as always, it's do as you want with your trailer.
Old 09-22-2021, 10:46 AM   #9
Originally Posted by mary and bob View Post
... As far as lifting a trailer to change a tire with any type of stabilizer, I don't think that is a good idea as you can distort the frame. Better to jack near the axle. But as always, it's do as you want with your trailer.
With the new BAL stabilizers, Scamp does place them closer to the axle. It's been reported that Scamp now endorses using them for tire changing. (I recall Floyd was the one who reported it, and I'd consider him a reliable source.) He has changed his to the new BAL style.
I have not, so I will continue to use a separate scissors jack (or floor jack at home) for lifting just behind the axle as recommended in the older manuals.
Old 09-22-2021, 06:03 PM   #10
I am just evaluating
The old original stabilizers don't touch the ground firmly reliably. One side will, the other will wiggle. Perhaps mine are just not functioning correctly anymore, my unit is a '95 19 foot scamp. it is old for sure.
That said, it seems to rely on a spring loaded widget pressing a flange into a hole... as I said, one side will press hard down onto the ground, the other just kinda flops around. And I don't see how I can somehow cause more pressure against the ground directly at the stabilizer. Which does not make for an ideal stabilization.
A scissors style would allow me to independently and precisely adjust each side, my objective. I read somewhere that scamp has moved to a scissors style for new units? If so that is not a glowing endorsement for the old style.
JWColby EAAT
Eggcamper Stabilizer Jack Letitia Problem Solving | Owners Helping Owners 23 08-22-2015 04:03 PM
Replacing Bumper Stabilizer Jack in '88 Casita Michele B Problem Solving | Owners Helping Owners 2 03-23-2011 02:32 AM
Questions on some specific scamp options Sandy Christie General Chat 6 01-25-2010 10:30 PM
Stabilizer Jack question DannyH Problem Solving | Owners Helping Owners 28 10-09-2009 02:06 PM
