Originally Posted by Donna D.
Your trailer, do what you wish. The reason Scamp no longer has a roof egress vent is because they're installing egress windows. My Scamp doesn't have that window, hence the big vent. I like it. Lots of air. I laugh when people talk about not being able to get up and out in case of a fire. I think it's more for if the door is blocked or somehow locked and you have no other way to get out.
When I decided to delete the escape hatches. I looked into this. The new Scamp trailers I looked at in 2020 had neither the roof hatch or the escape windows. The siding windows Scamp was using on the trailers that were on the lot at the time had the black framed sliding windows. The same as my 2008 19 deluxe. One time my entrance door got closed with the lock pin in the hole. The siding window was unlocked. I was able to enter the camper through the sliding window in the loft quite easily. My shirt size is XL and I had no problem fitting through the window. So, the standard sliding window on my trailer would be a suitable fire exit.
Now as far as the door being block, you have the large window in the back of the trailer would be the easiest way to exit the trailer.
As far as ventilation goes, everybody wants max air fans now, a 14"x14" crank up vent with a fan installed in the vent. And when an exterior vent cover is installed, can be left open in any rainstorm, will move more fresh air than the big vent ever would move. With the vent cover, the vent can be left open while traveling, and the fan could be left running.
Now, the roof hatch might have some problems being used for a fire escape. The hatch is in the highest part of the trailer. If the trailer is on fire, an open escape hatch would act like a chimney. The fire would be drawn to the opening in the roof, and you would be standing in the opening while trying to exit. The fire and heat would be drawn over your whole body. An open window a little bit lower, would have a little lesser effect on the fire, and most of the heat, smoke and flames would be above your body as you crawled out of the window.
The trailers with the older style crank out louvered window, I would think you would need to leave the hatches installed. You would have no other way out.
The newer escape windows are a good idea though. In a medical emergency first responders would be able to get a person out of the loft area much faster and be able to treat the person much sooner. This would make all the differance in the world if a person is in cardiac arrest.
