Screen door modification - Fiberglass RV
Old 06-21-2020, 08:10 AM   #1
CarlD's Avatar
Trailer: LiL Hauley
Syracuse, NY
My little hauley screen door, and many other brands, require you to open the sliding window to access the door latch when using the screen door, which I consider a PITA. I have seen some interesting solutions but opted for the simple pull cord shown in the attachment. I drilled a hole in the door and inserted a tight fitting plastic tube, a piece of spiralwrap in my case, drilled an appropriately sized hole in the door handle and ran a piece of small cord from the handle, thru the plastic tube and knotted it at both ends. Works great.
Old 06-21-2020, 05:57 PM   #2
charlsara's Avatar
Trailer: 2014 Lil Snoozy
Great idea.
Old 06-21-2020, 08:05 PM   #3
I like the idea. I get tired of opening the slide, they wear out and get all messed up quite often. But I wonder if a pet could pull on the rope and open the doors.
New Camper Mod: The modification you didn't know you needed (cat door) SnowballCamper Modifications, Alterations and Updates 2 05-03-2019 02:16 PM
Bi-fold Screen Door Screen Replacement Byron Kinnaman Care and Feeding of Molded Fiberglass Trailers 6 04-19-2019 08:04 AM
Screen door for Burro Legacy Posts Modifications, Alterations and Updates 28 06-18-2012 04:40 PM
Looking for screen room or screen panels Deb & Chuck Classified Archives 0 09-19-2009 04:07 PM
screen door Legacy Posts Modifications, Alterations and Updates 9 06-20-2003 11:38 AM
