I respect the amount of combined experience and expertise on this forum - so I will share my problem hoping to find a solution.
I realize this is not an RV query, but is related to our skills...
Our subdivision installed cast aluminum mailboxes, which are way to expensive to replace - so I would like to hear solid opinions on how to approach refinishing. They were originally powder coated, but apparently all pieces were not prepped and/or primed properly, since chunks of powder coating has lifted from the aluminum - some pieces of the mailbox assembly are completely bare, corroded (oxidized?) aluminum -- while others have fully intact powder coating.
The plan would be to clean and prep the entire mailbox - then
paint it to match the original color. The issue is what is the the best technique to use to be sure the bare, corroded, aluminum will allow the
paint to adhere? I have done exhaustive searching online without finding a consensus of how to do this?
Other objectives to bear in mind are: fastest drying time between coats and affordable products not requiring professional application -- I would like to use a roller and/or brush - preferably a water base?
Just a thought - some members have used a brush-on truck bed liner for stone guard on the front of their egg? I do not remember what the brand was, but one of them looked to be a thin and attractive after brushing on? Would such a product adhere in this situation - IF the correct color choice would be available?
Thanks in advance! Like myself - I know some of you enjoy solving problems. I can't wait to see what simple and creative ideas come my way!
