Storage ideas for Casita Spirit Deluxe - Page 2 - Fiberglass RV
Old 03-18-2024, 06:40 AM   #21
Originally Posted by Jennifer Minogue View Post
This is made from an Ikea shelf. I put the dishes on it and put hooks on the front to hold a rod for paper towels. This leaves the table below free for cooking, prep, etc.
I went a slightly different route to create an outside shelf for the side of the trailer. Since I already had a full-sized rimmed aluminum baking sheet pan, that wouldn' fit in my home oven and was basically useless, I adapted it for a new purpose. It has now become my new wheel well table. I did have to notch the rim "bead" on the sheet pan so it would slide into the Keder rail, but it sits in the rail perfectly. And it sits right next to my outside convenience outlet for a handy plug-in if I want to use my toaster oven.
Two pieces, which just slip together, so it doesn't add much weight or take up much space when not in use. The sheet pan lives in the little gap at the foot of my sideways permanent rear bed, against the wall below the TV shelf. The leg just lives in the front closet when not set up. I just made the base structure from some aluminum scraps I had left over from other projects. The Keder rail section was also left over from my new slide-in awning rail, also on the side of the trailer. Pretty much turned out as a no-cost addition.
It's simple, light-weight, easy to set up and it's strong. How strong you might ask? Well, after setting it up I "load tested" it by sitting my 220 Lb. carcass on it, and it didn't even groan.
Old 03-18-2024, 09:46 AM   #22
Casita Greg, whenever you get around to starting Little House Customs North, I'll be your first customer..;-)
Meadowlark is offline   Reply With Quote
Old 04-08-2024, 03:31 PM   #23
Dan Felipe R's Avatar
New Mexico
Hooks, can’t have too many hooks!
We inherited a few nice tweaks with our ‘08 Spirit Deluxe. Our favorite is the copious use of stick-on plasticcv hooks in the entry, above the dinette and kitchen, in the rear, for hanging up keys, jackets, hats, towels — all stuff that would sit on a table or counter or have to be put away when you’ll just need it right away.
Another is a simple plastic bar that screws onto the door below the sink, which you hang a throwaway shopping bag on for trash. Convenient and out of the way.
Dan
Dan Felipe R is offline   Reply With Quote
Old 04-09-2024, 04:09 PM   #24
Originally Posted by Casita Greg View Post
Actually, the lower "door" for my new accessible space below the large front cabinet door was the "cutting board" provided by Casita, which originally sat over the galley sink. I would never use that particle board for prepping anything on that I would eat, but it worked well to fashion into a new hatch door for my lower cabinet. The pop-up latches are available on-line. I bought a bag of them on Amazon. The hinges are standard 1/2" offset cabinet hinges, and can be found in the hardware section at any Lowes or Home Depot, etc.
If you don't have an extra piece of that "fake wood," that Casita uses, you could probably contact Casita and tell them what size piece you want. I'm sure they would sell you a chunk, but I can't say what shipping would cost.
I wouldn't want to use a particle board cover as a cutting board, either, so perfect reuse there. Unfortunately, ours didn't come with one.
We've already cut the hole under the closet and put a shelf between the bottom of the closet and top of the drawer beneath. Hubby wants a pull out drawer rather than an opening door for that bottom opening. I've been eyeing those cord/plumbing covers in various places and, if nothing else, may use one of the "wood" pull up access covers on top of the dinette seats and replace that with plywood. No one will ever see that and then we can have a matching door below the closet.
The one thing I'm having trouble finding is some edge trim that can fit over the cuts in the fiberglass. He did a great job doing the cuts, but he'd like to have that trim to finish it off before putting the slide out door in.
Thanks so much for the info!
Ericka O is offline   Reply With Quote
Old 04-09-2024, 05:18 PM   #25
tractors1's Avatar
Trailer: Escape 21 - Felicity
Go the the bath section of Lowes/Home Depot; there is an edge trim that used over the rigid stuff used to make showers. Works great on the fiberglass edge.
Charlie Y
Old 04-09-2024, 06:46 PM   #26
Hey, thanks! I'll check that out.
Old 05-07-2025, 01:35 PM   #27
Trailer: Casita Liberty
And I would be remiss if I didn't mention my Stow-Away rear hitch mounted storage box. Great place for all those bulky things like sewer hose and fittings, (coiled up in a 5 Gal plastic bucket,) patio mat, chocks, jack pads, hoses, cords, small rake, shovel, hatchet, etc.
Great way to add some "trunk space" for those things.
I love your white storage box on the back - could you provide a link where you purchased it? Thank you!
Margaret Jones is offline   Reply With Quote
Old 05-07-2025, 05:05 PM   #28
Trailer: Casita Liberty Deluxe
LA
I believe Greg is using the Stowaway2 Max Hitch cargo box. https://www.stowaway2.com/max-cargo-carrier-ivory
Some of us use a cargo carrier and a basic plastic box, I added a riser to get ground clearance.
Stowaway also sell a cargo box frame you can bolt a box to that has plenty of ground clearance that I have my eyes on.
We limit the weight in the rear box to the patio mat, a couple of camp chairs, awning sun shield, etc.
daveandalice is offline   Reply With Quote
casita
storage/space saving ideas for the 13' Boler CheekyTracy Fulltiming in a Molded Fiberglass Trailer 20 10-30-2012 08:37 PM
Storage areas in 17' Casita Spirit or Liberty deluxe Karalyn Problem Solving | Owners Helping Owners 0 10-24-2011 09:42 PM
Exterior Storage box ideas Cam A Problem Solving | Owners Helping Owners 17 05-15-2006 05:41 AM
Storage, Storage, and Storage Legacy Posts Problem Solving | Owners Helping Owners 18 11-20-2002 10:43 AM
Storage, Storage, and Storage Modifications, Alterations and Updates 0 01-01-1970 12:00 AM
