Strip of fiberglass missing - replacement ideas? - Fiberglass RV
Old 08-07-2020, 06:43 PM   #1
Trailer: compact jr
HI! I'm working on my Compact Jr pop up...The previous owners attached a window to the popup - permanently raising it up but not securing it to the body (see "BEFORE" photo). I guess they just had it parked somewhere. I tore that wood/window part off leaving a 6 feet long by 3 inches deep strip missing from both sides (see 2nd photo). I need to replace the missing material. I was thinking a strip of Plexiglass or metal or wood. What do you think would work best? It already has holes drilled so that's not an issue. Thank you all!!!!
Kris
KCan is offline   Reply With Quote
Old 08-08-2020, 04:51 PM   #2
Trailer: Casita 17 FD
Strip Replacement
There are a lot of options for replacing that strip. However, I would put plexiglass at the bottom of the list. Plexi is not very stable, some forms deteriorate in the sun (turn brown). All plexi is known to "cold flow." That means that under normal temperatures it flows, bends, moves, etc, as if it were just a very thick, viscous substance like molasses.
If it were me, I would look for fiberglass panel pieces. Maybe check at a boat repair or manufacturer. They often have FRP panels and pieces.
GatorCasita is online now   Reply With Quote
Old 08-08-2020, 06:58 PM   #3
John in Michigan's Avatar
I would "replace" the missing fiberglass section by laminating in 4 layers or so of chopped strand mat fiberglass. To determine exactly how to do this, check this thread:
https://www.fiberglassrv.com/forums/...ass-52498.html
Also check channels on youtube such as Boatworks Today...
Trillium 4500 Journal
https://www.fiberglassrv.com/forums/f...nal-81345.html
Old 08-08-2020, 11:36 PM   #4
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
I have noted that some people on the forum have replaced missing fiberglass to cover window openings etc. with old fiberglass tub surrounds like showers. Cut to fit and fiberglass in place.
Best of luck with your project.
Dave & Paula
Old 08-09-2020, 06:03 AM   #5
Dave & Paula
Dave's suggestion is even better. Fiberglass work requires some practice. One of my first fiberglass projects was to patch a hole in the bottom of my Trillium 4500 that was large enough to put my hand through, apparently formed by stone impacts over time(?). Your project is more challenging because it is plainly visible. You want it to look good. Nice thing about fiberglass is that if you don't like the result, you can grind it out and try again.
Old 08-09-2020, 07:20 AM   #6
FRED SMAILES's Avatar
Trailer: 13 ft Boler
Kootenay's of BC
I too think finding something made of fiberglass with a gelcoat finish that you could cut the strip the strip from.
I have used an old truck canopy for a slightly more involved project but same idea.
Pics starting at post 187
Fred
https://www.fiberglassrv.com/forums/...r-55601-8.html
I'd rather do it myself, done right or not. Isn't that what a hobby is all about?
https://www.fiberglassrv.com/forums/...ler-55601.html
FRED SMAILES is offline   Reply With Quote
Old 08-09-2020, 09:30 AM   #7
Steve Hammel's Avatar
Trailer: Casita SD 17
Loon Lake Wa. and Boulder City, Nv.
Find someone who has torn out a fiberglass tub or tub surround and cut off the piece that you need. Fiberglass is not that hard to work with especially if you are doing a patch. Cut it as close as you can get it, epoxy it into place and then when dry reinforce the back with some mat and fiberglass resin. Clean up the front with some bondo and away you go.
Previously Owned: Trillium 4500, Scamp 19', Bigfoot 17', Boler 17', Bonair Oxygen, Hymer Touring GT, Scamp 13 Deluxe.
Old 08-11-2020, 10:33 PM   #8
Trailer: compact jr
Wow. Looks like I'm about to learn another skill! Thank you so very much. I live in Los Angeles so hopefully I'll be able to find some scrap fiberglass strips soon.
BUT - do you think I COULD use wood?
I ask because I was hoping not to bondo & repaint.
Old 08-12-2020, 04:17 AM   #9
You can use any material you want. Is wood the best material for the job? No. Is plexiglass the best material for the job? No. Is metal the best material for the job? No. Is fiberglass the best material for the job? Yes! It's your trailer and your call.
Old 08-12-2020, 07:23 AM   #10
Kootenay's of BC
LA, with the surfboard shops and supply places you won't have any trouble finding supplies or knowledge.
Bet some board builder would probably do it for you,,,?
Fred
Old 08-12-2020, 04:25 PM   #11
Trailer: compact jr
OK - Fiberglass it is! I'll keep you updated and thanks for your input. I truly would be lost without it.
Kris
Old 08-15-2020, 10:31 AM   #12
Oldballer's Avatar
Trailer: In the market
If you are left with any cracks and holes to fill, I have repaired fiberglass damage with white Marine Tex. Pretty good product mixes like auto body putty
Oldballer is offline   Reply With Quote
Burro 1986 17ft ceiling strip ideas? minnie r. Problem Solving | Owners Helping Owners 7 11-18-2018 06:05 AM
Missing Fiberglass Camper Manufacturer? Alex Adams General Chat 5 07-26-2017 03:13 PM
Axle Replacement Ideas? Gorky Towing, Hitching, Axles and Running Gear 7 12-09-2016 12:46 AM
Rubber strip missing on bottom of Trillium back window parmtree Problem Solving | Owners Helping Owners 2 10-23-2014 02:55 PM
Mobius Strip Legacy Posts Jokes, Stories & Tall Tales 11 12-27-2002 07:02 PM
