09-24-2013, 09:02 PM
#21
whoo Peter, please pass onto Lynn that I think she is doing a great job oh her trailer!
Looking forward to seeing her interior design ideas!
So are you bringing the big trailer to next years Bandon meet and she will bring "her" trailer?
09-27-2013, 09:07 PM
#22
Our (sand) blasted trailer frame with metal supplies for reinforcements, a new bumper and a propane & battery tray (already started) up front.
The old bumper will get cut off and replaced by the L beam closest to us in the picture.
The sandblasting was $165 at BlastOff in Vancouver. Spendy, but the work was done in a single day and they were a joy to work with. (Dropped the trailer frame off yesterday evening and picked up today around noon.)
The metal supplies cost around $130, but I won't use all of the supplies I bought.
I need to make some trailer frame repairs. The bumper is cracked and rusted through in places, so that repair was pretty obvious. I was also concerned about the quality of a repair done in the yoke area where there's a hairline crack at the point where the yoke bends upward so the receiver comes up to meet the ball hitch on the tow vehicle. More concerning than either of these two is a hairline crack that was hidden under the trailer shell where the first cross-member meets the frame on the left.
While the rest of the frame is solid, if I hadn't done a frame-off with the trailer, I would not have found that hidden crack, and the frame would have failed someday while we were towing it. Once repaired, the trailer frame will be as good as new and will have another good 40 years in it as long as I keep rust-inhibitor paint on it.
09-29-2013, 01:37 PM
#23
More work on the trailer frame. None of the welding has been done yet, but I have cut and bent a new bumper, parts for the propane tank/battery tray up front, cut a new cross-member for the back part of the trailer to support our new grey water tank (not shown, because it's just a 44" long piece of angle iron), extra support "wings" that double the width of the frame under the back of the trailer (also not shown, because they are equally dull), and made two mending plates to repair a small crack at the front street-side end of the trailer.
All are waiting for a dry day when we can tow the trailer up to my father-in-law's (Lynne's dad's) house for welding. He's a trained welder . . . I just know how to putz around with one, and getting good welds on those mending plates is critical.
Our new bumper.
Propane and battery tray. (The long bits of angle iron are temporary supports that hold the back support in place.)
Spot that needs mending, with the top edge of the crack ground out a bit.
12g mending plates.
10-02-2013, 11:30 PM
#24
Originally Posted by Carol H
whoo Peter, please pass onto Lynn that I think she is doing a great job oh her trailer! Looking forward to seeing her interior design ideas!
Hi Carol!
Thanks! Progress is slow but steady. Tomorrow morning we are towing the frame over to my Dad's shop so he can do the welding for us. In the meantime, the punch list for the exterior body repairs is getting very short indeed. I sure hope these endless rainy days let up for a bit so we can start priming and painting.
I was thinking that we would just bring the Surfside to Bandon next year. And then Peter mentioned that maybe we should take both trailers! Just when you think you know your husband. . . . I wonder if he plans to sleep in "his" trailer or come join me in "mine"
--Lynne
10-03-2013, 07:49 AM
#25
Nice work Peter (as usual).
I'm wondering if the belly band on the Surfide is similar to that on the Trillium? Will there be the potential need to do that fix in the future?
10-03-2013, 09:26 AM
#26
Roy: No, the Surfside has a lap seam with the top half of the shell overlapping the bottom, riveted in a few places, fiberglassed on the inside, had a former fiberglassed in on top of that, then riveted again as the bellyband trim was added.
I've smeared Bondo over all the exposed rivets that are poking through.
As for my wife, it'm glad I can still surprise you now and then. Keeps the magic alive. And it's been a long time since we've had to figure out the "your place or mine?" thing.
10-05-2013, 01:13 PM
#27
Hey... get a ROOM!
10-05-2013, 09:09 PM
#28
When this trailer's a rocking, I need to put the stabilizers down. ;-)
10-05-2013, 09:24 PM
#29
Trailer frame back from the welder.
After staying up late on Tuesday and starting early on Wednesday getting the metal parts for the trailer frame cut, we drove/drug the trailer frame and metal work I'd done to Lynne's Dad's shop on Wednesday.
Lynne's Dad can weld and has good equipment. I play with metal and have the cheapest wire-feed welder Harbor Freight sells.
Lynne's Mom and Dad showed up with the frame this evening (Saturday). The frame repairs are done, new bumper on, a new propane/battery rack installed, one new cross member has been added and another moved to accomodate our new grey water tank (which I've tucked into it's proper spot in the picture), and we have added little "wings" that double the width of the frame the shell rests on in key places.
The axle will get replaced soon, too. And the last of the exterior Fiberglass work we need to do before we get to painting the shell will be finished today!
10-06-2013, 01:34 AM
#30
And the refit saga continues . . .
Many, many holes were patched, sometimes moved, and often repaired in our Surfside. Some of the larger repairs (after replacing the floor) were fixing the rips in the wheel-well fiberglass. My how-to for this repair is posted here.
Before:
After:
10-08-2013, 03:00 PM
#31
Fianally getting to paint.
Yesterday we put primer on the bottom half (below the belly band) of our Surfside. Today we'll get the top half. We're using Rustoleum marine primer for wood and fiberglass above the waterline. Top coats will also be Rustoleum's "Topside" marine paint.
I haven't talked much about how we did our "frame-off," which was a minor hassle that others have discussed at length. Something we have done that's different is construct a dolly to support our trailer while it's separated from its frame from 2x4 lumber with heavy-duty caster wheels at each corner.
When we want access to the bottom part of the trailer, we jack the dolly up with a floor jack and put it down on four jackstands. When we want to work on the top or move it around in the shop, we drop it down to these 250 lbs capacity caster wheels.
10-25-2013, 09:50 PM
#32
Gotten a few more things done. The shell and frame have been primed and painted, installed rear stabilizers and a gray tank on the frame, and moved the frame under the shell.
YES! The shell now sits on (but has yet to be bolted to)its frame. Finally!
THe paints, by the way, are all Rustoleum. Rustoleum metal primer and paint for the frame, Rustoleum Marine Topside primer and paint for the shell. I'm fairly impressed with Rustoleum Topside; there primer plus three top coats on the bottom, primer plus four four top coats on top, all applied with a foam roller.
05-28-2018, 01:31 AM
#33
We haven't posted in a while. Life got very busy -- crazy busy -- for me. Some health problems, my Dad died, and a few other complications . . . all while I was running for Congress. My plate is still pretty full, but endorsing another candidate and pulling out of the political race freed up some time for dealing with my (surviving) Mom's finances and estate issues.
Anyway, leading up to all that several things moved forward on the Surfside. We embedded two fractal TV antennas inside the shell, installed Reflectix insulation and rat fur (er, marine headliner) on the walls and ceiling, trailer-long LED lighting tracks, built a bed platform, roughed in the cabinets and dinette seating and installed the upper cabinets. That's where the trailer stood at the start of March.
More recently we built and installed the upper cabinet doors, ran the gas piping for the 'fridge, furnace, cooktop, and "instant on" water heater, and are now working on the kitchen counter, backspash, and stovetop hood. I've also been teaching Lynne how to do basic cabinet making. She built most of the doors, and did much of the work on a knife block and spice rack.
I have a picture to share with more on the way . . . It's nice to be back.
05-28-2018, 01:50 AM
#34
A few more pics. From the front window toward the back with the LED lights on, two pics of the exterior setup lights and lights in the under-bed storage, and the alpha version of my TrailerLevelHelper electronics project, where you can also see the water filter install. More on LevelHelper as it gets to the Beta version.
05-29-2018, 01:42 PM
#35
Trailer: Currently Shopping
I love the hatch. Can you tell me what the size is? I have a SurfSide as well and adding hatches to access the back benches will be the most useful modification I can think of.
And did you build a wooden frame to support it on the inside? Or how did you attach the hatch?
05-29-2018, 05:51 PM
#36
Peter, I am sorry to hear about your dad, I hope your mom is doing OK.
It is good to have you back! I love what you are doing with your Surfside. Can you tell us more about the LED strips you are using? I gota think that the setup lights are in for a rough ride. How are they supplied with power? Did you use any fittings to go through the shell?
05-29-2018, 08:22 PM
#37
There are two different T&H marine locking hatches. Both are 13" high at the face (about 2" smaller for the opening through the fiberglass), the driver's side hatch is 24" long and the curb side 30" long.
Yes, both connect into wood frames on the inside but, even more important, both required that I build up the fiberglass using Bondo at the lower rear corners and along the lower edges of the openings. The Surfside natural curvature doesn't fit the doors.
The same goes for the opening for the instant water heater I installed. The Surfside natural curves are just a bit too sultry, so the old girl had to put on a bit of weight in a few places. You could install hatches that aren't quite as tall, but then they would also make accessing the storage area harder.
05-29-2018, 09:04 PM
#38
The exterior setup lights are self-stick "12v IP65 waterproof cool while LED 5M strip" (quoting the search you use to find them) lights for about $8 from eBay. They come on 5m reels, more than enough to install a strip over each wheel well, across the back of the trailer, two shorter strips on either side of the tongue, with a few feet left over to light the storage area under the bed where the trailers dinette used to be. I also installed setup lights behind the exterior refrigerator door to make it easier to see that area and light it at night. Once the trailer is road-ready they will light when the tow vehicle backs up and the back-up lights come on, bu there's also a "setup-lights" switch just inside the door.
Installing them requires some patience in trimming the waterproof covering back from a segment cut to the desired length and some soldering skills. The downward-facing holes for the wires are plugged with hot-melt glue. I may have to up my game on the sealant to an RDX or marine sealant product.
The adhesive on the back of the self-stick strips is kind of wimpy. I'm expecting it will fail and have already bought some 1/4" 3M VHB mounting tape to more permanently attach it.
The interior lights are "12v warm white non-waterproof LED 5M strip," and are mounted to a white plastic 90 degree molding piece from a hardware store that I've painted to match the rat fur. 5M is enough to run one continuous 8' strip down either side of the ceiling. I attached them to strenghener/formers made of 3/4" PVC irrigation piping that have been fiberglassed into place every 18" across the center part of the ceiling to combat roof sag. I'm not sure where my posts about how I did that have gotten to . . . It's been, quite literally, years since I fixed our sagging roof.
05-30-2018, 06:36 PM
#39
Kitchen counter starting to take shape
The cabinet below is a skeleton, there are trim pieces missing and the sink isn't plumbed in yet, but the kitchen is starting to take shape.
We made the knife block, (magnetic) spice rack, and stove good. More on the last two later.
05-30-2018, 07:00 PM
#40
New magnetic spice rack
I built a spice rack for our Scamp 5er ( http://www.fiberglassrv.com/forums/f...ack-31154.html), and Lynne and I really like having a bunch of spices at hand when we cook. Problem is, we can't find those short, stubby metallic cans anymore, only similar, taller ones, and the craft-store self-adhesive magnetic strip we used in the Scamp lost it's oomph. It used to be it took a really rough road to knock even one spice loose. Nowdays it takes a minor bump and everything comes loose. (SOmething I have to fix before we sell it.)
Either way, it's time for a new design for a our Surfside's spice rack.
The trick this time is to buy 10mmx2mm Neodynium N-52 magnets and install them in a groove, one behind each spice container, and alternating their magnetic poles (N-S-N-S-N-S-N-S-N-S), then put a strip of iron metal (a hacksaw blade was the exact right size) to amplify the magnetic face outward toward the spices.you can sake this thing really hard and nothing falls out.
I used a router to cut a 1/2" groove down the back of the 1/8" thick birch plywood back and mounted the magnets using Gorilla urethane glue. Clamping was easy. I just put the metal ruler from my combo square across the front side.
Because magnetic strength deteriorates at the square of the distance, you want to cut a grove for the magnets if you possibly can to keep the magnets closer to the thin metal of the spice cans.
