Surfside Roof Vent Replacement - Fiberglass RV
Old 06-27-2022, 03:11 PM   #1
Trailer: 1976 Surfside
Saskatchewan
I am looking to replace the current roof vent on my SurfSide trailer.
The current roof vent is approx 9" x 9". However, with the new vent I am hoping to install something larger.
Would this simply be a matter of enlarging the current vent opening and installing the new roof vent? Or would there be a need install some sort of new 'backing' or 'support' around the new opening to hold the new, larger vent.
Not sure if anyone has done this before. Any advice is appreciated.
Thank you in advance,
Joel D is offline   Reply With Quote
Old 06-27-2022, 04:00 PM   #2
David Tilston's Avatar
Joel, This has been done several times. Some have simply cut the hole larger. Others have used wood to make a frame on the outside. I would use pultruded fibreglass to make a frame on the outside:
https://www.grainger.ca/en/product/S...-FT/p/WWG4ATN8
If you are currently dealing with some roof sag, then it is possible to use a piece that is incorporated into the frame that spans across the trolly section of the roof, to support the sagging section. I would cut the ends at a 45° angle to help conceal the square tube.
surfside
New roof vent for Trillium 4500 designed for thicker roof Vic Berger Problem Solving | Owners Helping Owners 1 07-07-2020 07:40 AM
Anyone know how to fix a saggy roof in a Boler??? (around roof vent) idiotsniff Problem Solving | Owners Helping Owners 31 11-17-2014 06:50 AM
Protecting The Roof & Roof Vent Covers , AC, This Winter ???? John Cole Care and Feeding of Molded Fiberglass Trailers 25 01-15-2013 05:57 PM
To Roof Vent, Or Not To Roof Vent Frederick L. Simson Problem Solving | Owners Helping Owners 5 02-22-2009 05:41 PM
Replacement roof vent Cam A Problem Solving | Owners Helping Owners 10 03-18-2008 12:08 PM
