Surge brakes or electric brakes? - Page 2 - Fiberglass RV
Old 07-07-2019, 07:27 PM   #21
Borrego Dave's Avatar
I had hydraulic surge brakes on my car trailer that I towed for years behind the class A to the desert. Total weight of the buggy and trailer was 3500#. The road to the desert floor dropped 3500' in 10 miles with 86 turns, I never experienced any fade. As I recall the coupler, it could moved quite a bit with the amount of braking I made in the tug, from nothing to full on. The farther the coupler was forced back, it fed more pressure to the brake cylinders just like it would in your car. As far as backing up, with a fairly flat surface, the coupler never moved enough to hinder the backing. Trying to push it up an incline was another story. You had to put a pin in the coupler to keep it from moving. So, from 10 years of using that set up, the only minus would be not being to apply the brakes moving forward for possible sway. YMVV
Old 07-07-2019, 07:34 PM   #22
Just curious. Why haven't surge brakes been widely adopted by the RV industry?
Old 07-07-2019, 09:24 PM   #23
Modern electric trailer brake controllers are designed to be proportional, with adjustments so fine as to enhance overall trailer control.
Some newer electric trailer brakes are even self adjusting in forward or reverse.
Even though manual override is almost never needed, most see it as a plus.
I remember the VHS vs BETA argument. "which is better?" became irrelevant, VHS won, and both eventually proved inferior.
My money is on electric trailer brakes, leaving a small niche for other forms, such as surge or electric over hydraulic.
But like Beta or VHS we may see computerized trailer systems completely independent of the TV, only relying on a coupler for motivation...
Or who knows? Self propelled and programmed to follow the
VMFKAT (vehicle module formerly known as Tow)
For now the best system for small to medium travel trailers will remain electric trailer brakes with proportional controls.
Old 07-07-2019, 09:41 PM   #24
Darn. Nobody fell for it.
Old 07-07-2019, 09:46 PM   #25
Scamper Jim's Avatar
Glenn,
My guess is that they have difficulty finding qualified workers who can properly install and bleed the brake lines after assembling the components, nor do they want the liability of having to do so. It's easier and cheaper to install electric brakes and have the customer buy and install the controller. It shifts the liability for any faulty installation away from them.
Scamper Jim is offline   Reply With Quote
Old 07-08-2019, 01:23 AM   #26
OCJohn's Avatar
Trailer: Hymer
My guess would be cost. Electric brakes are cheaper and easier to install. And cost of the controller is not part of the cost of the trailer.
OCJohn is offline   Reply With Quote
brakes
Casita 1993 surge brakes FTTRV Towing, Hitching, Axles and Running Gear 1 10-05-2013 11:06 AM
electric vs. surge brakes Bill in Pittsburgh General Chat 11 11-21-2011 08:15 AM
Bleeding Surge Brakes on a UHaul VT Kevin A Problem Solving | Owners Helping Owners 2 04-27-2011 12:36 PM
Switching from Surge to Electric Brakes? Kevin A Towing, Hitching, Axles and Running Gear 9 06-18-2007 10:00 PM
Electric Brake or Surge Brake? Bonnie Barge Problem Solving | Owners Helping Owners 28 08-28-2006 01:44 PM
