Swivel table - Fiberglass RV
Old 11-08-2022, 06:01 PM   #1
West Virginia
Swivel table
I want to put a Lagun-type table in my Casita FD. Has anyone used the round leg that is standard for this trailer to mount the Lagun table? Is there an adapter or something to use? This table will be in the back of the trailer and I want it to swing around for use or to store. Any thoughts will be appreciated.
Thanks.
RLJR is offline   Reply With Quote
Old 11-08-2022, 07:36 PM   #2
I don't think the pedestal leg is strong enough to support the cantilevered weight of the table and everything on it. In fact, even attaching it to fiberglass cabinets requires reinforcement on the inside of the cabinets.
Old 11-09-2022, 06:22 AM   #3
West Virginia
Table
After your comments, I took a second look. I can reinforce the side and mount the Lagun table without much to do.
Thank you
Old 11-09-2022, 07:13 AM   #4
Trailer: Casita Liberty Deluxe
LA
Lagun Table
Ours was previously attached to the side of the fiberglass bench with a 3/4" a 3/4" plywood backer and two heavy duty shelf brackets to eliminate flex.
I moved it to the rear to add an access door in the bench and it is so nice in the new location.
Here's a link to the thread on Lagun installs.
https://www.fiberglassrv.com/forums/...ble-99632.html
daveandalice is offline   Reply With Quote
Old 11-09-2022, 07:18 AM   #5
West Virginia
table
The water tank is sorta in the way. I am thinking if I use plywood and braces I may have to pull the tank. The worry now is to end up with a level place for the tank. Screws not flush over time would rub a hole in the tank
Old 11-26-2022, 10:58 PM   #6
Trailer: t
My husband and I are doing the same! And I found interesting solutions here!
karenkresgs is offline   Reply With Quote
Old 11-27-2022, 06:22 PM   #7
Trailer: 13 ft Scamp
I’m also considering going this to the front bench ( then leaving table in back as permanent bed)
On my casita patriot 13’ standard model so I’m looking for ideas to strengthen the fiberglass base as well as table top ideas
So any and all ideas & pictures are appreciated
Swivel jack stuck. chrispy35 Problem Solving | Owners Helping Owners 4 04-28-2011 08:24 PM
Casita swivel chairs and table-North, TX Greg A Classified Archives 0 11-05-2008 06:16 PM
Swivel hitch Marie K. Problem Solving | Owners Helping Owners 8 10-27-2008 12:20 AM
WANTED: swivel captains chairs Betty L. Classified Archives 3 06-30-2006 08:14 PM
swivel sweeper Christi V. General Chat 2 05-31-2006 07:32 AM
Copyright ©2000 - 2023, vBulletin Solutions Inc.
