Tired of jacking up and down! - Fiberglass RV
Old 08-20-2021, 01:09 PM   #1
Trailer: In the market
Been thinking of this one for some time now. Unfortunately I had to replace my original jack to get one with top access. The side crank on the original jack was curved too close to the column to allow for this kind of mod. Just a simple piece of brass hex bar stock, a little drilling and tapping. I used 3/4 inch to be compatible with the drive screws on the stabilizer jacks. (And I had the piece of stock in my scrap brass bin)
Yellowjacket is offline   Reply With Quote
Old 08-20-2021, 01:29 PM   #2
Trailer: Scamp 1995 19'
Me Too!
I have the 19' Scamp with landing gear and a very low gear ratio crank. Lots of turns to get anywhere.
I've been thinking of the same thing. I think I have to buy a second crank handle and cut it off to make something to fit my drill.
Good job on your mod!
jwcolby123 is offline   Reply With Quote
Old 08-20-2021, 02:33 PM   #3
[QUOTE=jwcolby123;823078]I have the 19' Scamp with landing gear and a very low gear ratio crank. Lots of turns to get anywhere.
Doesn't your Scamp have a two speed gear box like on big freight trailers ? On those you push in the handle for one speed, pull it out for the other.
Old 08-20-2021, 05:31 PM   #4
I use my Dewalt power drill for the stabilizers and the Ultimate Jack is easy to setup as it has locking pin that lets you raise an lower it a lot quickly and easily.
Old 08-20-2021, 07:09 PM   #5
Great conversion, but it can be done just as easily with a side crank.
Side (curved handle) crank converted...
Even saved the original handle in a box somewhere. (for no good reason)
Battery drill or BAL stabilizer crank works it...
This conversion is a simple piece of drillrod with a hole drilled for the rollpin to hold the pinion gear.
I welded a nut on it for the wrench.
It could be done with a cut off shoulder bolt to avoid welding.
Old 08-20-2021, 07:15 PM   #6
[QUOTE=mary and bob;823088]
Nope. The scamp has a pin through holes, allowing you to drop and raise each foot independently by large amounts. However it takes about 10 cranks just to drop the cup down onto the ball of the hitch.
Old 08-21-2021, 09:49 AM   #7
WaltP's Avatar
Trailer: 2017 Escape 17B
SW Virginia
Fun mods, but I took the lazy way out and use a power jack. A bit over $100.
Walt
Old 08-21-2021, 10:25 AM   #8
GOB
Trailer: Scamp 19
Been using a drill on my Scamp 19 since we bought it. So much easier and faster.
GOB is offline   Reply With Quote
Old 08-21-2021, 10:46 AM   #9
What did you use to make the crank?
Old 08-21-2021, 10:51 AM   #10
GOB
Trailer: Scamp 19
I bought a piece rod and a sleeve at Lowes. Pinned the rod and sleeve together and cut a slot in the end of the sleeve, just use the hand crank as a pattern.
Old 08-21-2021, 02:45 PM   #11
Ohio
Great mods, but not for me. My wife likes to raise and lower the jack. I need to be careful not to get hit in the head while plugging in and attaching the chains.
Tony D is offline   Reply With Quote
Old 08-25-2021, 01:04 PM   #12
Trailer: 16 ft Casita
You know they make a hitch jack that you use your drill on.
johnlochbuie is offline   Reply With Quote
Old 08-25-2021, 02:35 PM   #13
WaltP's Avatar
SW Virginia
Link?
Old 08-25-2021, 06:41 PM   #14
David Tilston's Avatar
Originally Posted by WaltP View Post
Link?
https://www.ebay.ca/itm/234086763846?epid=4030742035
https://www.ebay.ca/itm/255107846576...item3b659cd1b0
Old 08-26-2021, 10:25 AM   #15
Trailer: Scamp 19ft
Nova Scotia
scamp 19 drill for landing gear question
I can use a drill to lower the 19er, but have you been able to use a drill to raise it? Our old 19 from '86 does not have the pins that allow for rapid dropping of the landing gear....therefore, endless tedious cranking.
kenbmcg is offline   Reply With Quote
Old 09-02-2021, 01:51 PM   #16
Trailer: 2013 Scamp 13 S1 BB
IL
Do people really find the manual crank that frustrating? I usually use 1 finger to quickly get the jack down to the ground and then its only but a few turns with very little force to get the scamp level. Then the same in reverse, no battery or drill to worry about. Not trying to be a smarty pants about it, just wondering as this is about last on my list of ideas? I had the chance to change jacks last year when I needed to make a modification to fit a tongue box. I chose instead to just reweld the jack to face forward.
Gompka is offline   Reply With Quote
Jacking up Scamp 16 - Did I do it right? PeterNY Problem Solving | Owners Helping Owners 19 04-27-2021 10:02 AM
jacking advice pls for 17.5 ft Bigfoot trailer FRL001 Towing, Hitching, Axles and Running Gear 5 06-03-2017 10:00 AM
Jacking up and removing frame on Boler 1300 BarterBoler Modifications, Alterations and Updates 1 07-06-2013 12:13 AM
Jacking up M-16 for axle work question GMike A Towing, Hitching, Axles and Running Gear 13 03-17-2013 06:35 PM
Jacking up Trillium on axle stands? Robert St.Louis Care and Feeding of Molded Fiberglass Trailers 10 10-13-2006 06:50 AM
