Howdy, I've started replacing the toilet in my
Burro. I've got the old one removed and cut out the pedestal it was sitting on. The connection looks to be ABS pipe that goes through the floor into the black tank via a rubber sleeve (rather than screwed into the black tank). My question is, will a closet flange fit into the existing ABS pipe or should I remove the pipe? The Burro's old toilet connection was non-standard, there was no toilet flange, and the closet bolts were fiberglassed into a custom made pedestal. I wasn't sure how a standard RV toilet connection is normally done. Anolther question, is there any difference between a household closet flange vs. one for an RV toilet? Is there a particular toilet flange I should use? Thanks in advance...
While shopping online for a Thetford Aqua Magic V, I found that the manufacturer has a $25 rebate. I was planning to get the toilet from Amazon for $125, and with the rebate will come out to $100 + tax which is a great deal. Here's the link to the rebate for folks looking for a Thetford.
http://www.thetford.com/Portals/0/PD...ate_coupon.pdf
