Trailer Tonge box for 13" Scamp - Fiberglass RV
Old 07-12-2020, 03:04 PM   #1
chse's Avatar
Trailer: 13' Scamp
Haven't posted here for along time, but thought I share this. I was looking for a tongue box that's fits my 2003 13" Scamp for a while and finally found one that works quite well. It is a Lund 6134T. I needed to prop it up with two pieces of plastic wood between the frame rails and the box to still be able to flip the front wheel. Originally I wanted to put an outside kitchen and my battery and solar charger in it. The box was too small to instal a stove but I use the lower part for the solar stuff and an upper compartment for storage. I also put a hatch to have access to the battery and solar charger and cables.
chse is offline   Reply With Quote
Old 07-13-2020, 09:06 AM   #2
chse's Avatar
Trailer: 13' Scamp
Old 07-13-2020, 10:03 AM   #3
tongue
original owner of our 13 put a 13in extension on the tongue makes it back so much better. plenty of extra room also!
Old 07-13-2020, 05:36 PM   #4
Markz's Avatar
I am building something similar. Click image for larger version
ID:	136001Click image for larger version
Markz is offline   Reply With Quote
Old 09-11-2020, 07:12 AM   #5
Trailer: 2013 Scamp 13 S1 BB
IL
The aluminum boxes are quite heavy, I went with plastic. Mine holds solar charger, group31 battery, 20lb propane and all the cords, hoses, and chocks.
Gompka is offline   Reply With Quote
Old 04-27-2025, 06:52 PM   #6
Illinois
Did you make a hole in the box and set it over the propane, or did the propane bottle fit inside the box?
Silverado is offline   Reply With Quote
Old 04-27-2025, 07:46 PM   #7
IL
Hole in the box both for the bottle to fit and as ventilation for any leaking propane.
Old 04-27-2025, 07:49 PM   #8
Illinois
Any pics of the side of the box that faces the trailer?
I just bought a very similar box, and I'm trying to figure out the best way to get it installed. Any tips or tricks would be much appreciated!
Old 04-27-2025, 07:51 PM   #9
IL
My 13 is long gone, but all you need to do is center the box and make sure you leave enough space behind it for the lid to have enough clearance to open. If you kept sewer tube holder the box will only open about 80% of the way.
Old 04-27-2025, 07:53 PM   #10
Illinois
How did you attach the box to the frame?
Old 04-27-2025, 07:54 PM   #11
IL
I just used self tappers and large fender washers. You could also use square U- bolts if you didn't want to make holes in the frame.
Old 04-27-2025, 07:58 PM   #12
Illinois
Sounds good. Thanks for the reply, I appreciate it.
Does it matter if the wires go "through" or "to" the battery? robf Electrical | Charging, Systems, Solar and Generators 13 03-22-2020 09:08 PM
"Camping" vs. "Traveling" Timber Wolf General Chat 54 08-07-2016 12:32 PM
Some "before" and "after" shots..... Don & Viv Modifications, Alterations and Updates 13 07-29-2010 04:52 PM
Tongue Box "repair" Kenny H Care and Feeding of Molded Fiberglass Trailers 0 09-25-2008 02:07 PM
» Trailer Showcase
Parkliner
DJO
The Pod
Erin C
