Vent epoxy removal SCAMP - Fiberglass RV
Old 04-29-2022, 10:30 AM   #1
Hi. Replacing roof vent. Any suggestions on how to remove (product or methods) all the old epoxy so I get a nice clean exterior surface to start fresh with the new vent?
KKScamp04 is offline   Reply With Quote
Old 04-30-2022, 07:13 PM   #2
Trailer: 2006 Scamp 19 Deluxe
Enchanted Mountains of Western New York State on the Amish Trail in Cattaraugus County!
I doubt that Scamp used epoxy. just scrap it off with a putty knife.
parmm is offline   Reply With Quote
Old 04-30-2022, 07:49 PM   #3
Parmm has the answer. Epoxy does not stick to poly so it just may scrape off.
Old 04-30-2022, 08:34 PM   #4
John in Michigan's Avatar
Trailer: 1979 Boler 1700
Kathy, if epoxy was used by a previous owner while installing or repairing a roof vent opening, around the edges, etc, then note:
Epoxy is frequently used to modify or repair molded fiberglass structures and surfaces that were originally fabricated with polyester resin, fiberglass and gel coat. If done right, the epoxy will be stronger than the original fiberglass. Similar to polyester resin based fiberglass, the epoxy modification or repair can be removed using a grinding flap disc or blade or bit, or a power sander using coarse sandpaper.
Epoxy, Gel Coat, Bondo, fiberglass repair KevinScamps Modifications, Alterations and Updates 17 09-27-2016 07:07 PM
Walmart Epoxy? Bluetang99 Modifications, Alterations and Updates 27 04-15-2016 07:40 PM
Building a bunk.. Epoxy or PL ????? babs08 Problem Solving | Owners Helping Owners 7 03-15-2015 07:34 PM
Which epoxy/resin to seal belly band on Trillium? Gumpit Modifications, Alterations and Updates 4 11-10-2010 02:38 PM
an epoxy on both your houses Ian-Vicki Problem Solving | Owners Helping Owners 12 06-14-2008 09:20 AM
