02-20-2019, 02:03 PM
#41
Trailer: Trillium Jubilee
Whatever happened to jalousie windows? We can have all our jalousies open in a rains torn and nothing gets in to our Trillium.
02-23-2019, 11:46 AM
#42
Ventilation Suggestion.
Conditioned air in foul weather is extremely important to avoid claustrophobic discomfort and interior water damage. Stock small trailers have limited electrical capacity which makes relying full time on fans less than ideal. In moderate temperatures, maximizing natural cross ventilation may do the job without reliance upon electrical power.
To maximize NATURAL cross ventilation should be easy in principle because the wind will supply copious amounts of outside air if its internal flow can be conditioned and controlled. Two things are required to do that: Air, free of precipitation and supplies from any direction. This last requirement is particularly demanding since wind direction is likely to change often with violent weather. Air, free of precipitation can be had by robust adjustable window awnings covering all opening windows. Presently, a robust window awning for the Casita's large aft window has never been successfully installed because of fitment problems.
I am presently working on robust fitment of an aft window awning to solve this problem and allow open windows for both air ingress and egress free of precipitation. This solution, if it works, should greatly improve Casita habitability in inclement weather without dependence upon electrical power.
02-23-2019, 12:56 PM
#43
Trailer: BigFoot
Stephen, Please keep posting on what you are doing and throw in a few pics. Sounds very interesting.
02-23-2019, 01:21 PM
#44
I'll be glad to keep you posted on my aft awning project. It is clear from the advice of experts that many attempts at aft awning fitment have been total failures. The posts here testify to the need for great strength to withstand storm stresses. My present thinking is a successful fitment will only be had with machined or 3-D printed components. I anticipate a prototype within 30 days. It is clear that the correct fitment of a simple accessory like an awning can have HUGE implications for the habitability and usability of the entire trailer. We'll see.
02-23-2019, 05:33 PM
#45
Trailer: scamp
Indiana
scamp air leaks
I have a 16 foot scamp. I have a fantasic vent on top with a cover. That handles the outflow The scamp has some air leaks like under the door and some other places that I can close up, but if they are not closed up will handle the inflow.
02-23-2019, 10:19 PM
#46
Louisiana
Originally Posted by Gerry
J-channel sure would be cheaper then the EZE RV rain gutter system I priced on line and you had to by 50 ft.
Thanks
I always try to think outside the box and somehow this escaped me.
You will have to trim back the nailer strip to about the height of the outer lip.
Clif
02-23-2019, 10:22 PM
#47
Trailer: 1978 Trillium 13 ft
Regarding Pat Thomson's question:"Whatever happened to jalousie windows?...Must be they outlawed jalousie windows. Why else wouldn't RV mfr's still use them?
marvonw
02-23-2019, 10:35 PM
#48
Because they don't seal sufficiently, resulting in drafts. People don't like drafts unless they paid for A/C.
02-23-2019, 10:38 PM
#49
Good to know. Thanks.
marvonw
02-23-2019, 10:53 PM
#50
Trailer: Trails West
Customers who have not worked in manufacturing rarely understand why things are the way they are. They think every thing is clear cut and obvious based on their personal wants and needs. But that is not how it works.
Jalousies have their issues such as it takes more labor hours to produce them being a biggie. More chances for something to go wrong with them, another biggie for the makers of the trailers. The reason for those two things is all of the moving parts involved in creating that window system.
Sliding and awning windows are much easier to produce, install and fine tune before they leave the factory. They have fewer problems in service because they are less complex units. This leads to a reduction in service calls for repairs and also fewer bad reviews both of which matter quite a lot when you are in the business of manufacturing and equally important to the dealers.
So awning windows became the choice to put into units to allow for ventilation during rain. Another major factor is the small segment of the market of trailers that have sloped walls was not enough to impact the volume of sales of windows styles that are more suited to flat sided trailers and motorhomes but not so great on sloped wall units. The larger market section trumps every time when it comes to what is getting produced for sale.
Another factor for loss of jalousie window maker's is in homes the jalousie window market declined due to their vulnerability for home intrusion and the difficulty of installing security alarms on them.
02-24-2019, 05:55 AM
#51
I agree with Glenn and KC’s assessments regarding the reasons for the decline in jalousie windows- cost, complexity, and greater potential for leaks and other warranty issues.
When jalousies were common in travel trailers, A/C was unheard of. Now that A/C is ubiquitous, jalousies just leak out all that costly conditioned air. Don't know if that's progress or regress, but I digress...
Responding to Pat's question, I would mention that Scamp has installed radius jalousies on all the side windows in every model since around 2010 and the sky hasn’t fallen. It didn’t raise the price significantly, and most people seem satisfied with their performance. Long-term they’ll probably have more issues than sliders, but folks seem to accept that in return for the benefits. They’re made by Hehr, so parts and seals are available. Radius jalousies don’t give quite the wide-open ventilation of traditional full jalousies, but like the old style they can be left open in the rain, and they open wider than awning windows to catch more breezes.
So, the jalousie option is still there (Trillium Sidekick used them, too), but...
In the context of this thread, Bigfoot is a four-season trailer with thermal (double pane) windows. It would not be practical to make thermal, jalousie-style windows due to the complexity and inefficiency of the seals. That's also the main reason they disappeared from the residential market.
02-24-2019, 08:02 AM
#52
Trailer: 2003 Casita 17' SD Deluxe, Towed by '09 Honda Ridgeline.
Seems like, to bring wet air into the camper during rain would actually increase the moisture inside ! Especially along the path between the window and the fan.. NO ?
My understanding of those rear window vents was to keep RAIN from entering, in the event that rain started while that window was open.
02-24-2019, 08:23 AM
#53
Ventilation during rain
If a trailer is closed tight, the heat and moisture of human activity is added to the ambient humidity. That will quickly turn into a sauna. With some ventilation, it will be no worse than outside. Moist cool air is better than moist warm air. Unless there is mechanical dehumidification happening- A/C running- that’s the best you can do.
02-24-2019, 11:20 AM
#54
Trailer: casita
Connecticut
Easy and effective solution
When we were Casita shopping, one of the demonstrating owners gave the following suggestion which is simple and very effective. We use it only on the two side windows over the bed simply because that's all the ventilation we need during rain and most other times.
Purchase a piece of plexiglass at a Depot store. There is a standard size which when cut in half it's perfect for your Casita. The finished halves will be about 15 in by 18 in (guessing here as Casita is stored away). This stuff is only about 1/8 inch thick and can be easily stored behind your dinette cushion. When rain is threatened, simply attach one of these outside over the window in question using masking tape all the way across the plexiglass. Do this before it rains as I do not believe tape will stick to wet fiberglass. A support strut, perhaps 8 in long, rests on the outside window ledge and the bottom of the awning to hold the bottom of this homemade awning away from the window allowing ventilation. you might hold that strut in place with some Velcro. you will be able to open your windows maybe 8 in allowing for sufficient overlap to keep rain from entering. We often run the ceiling fan with these awnings in place if we need more than natural ventilation. It does not pull rain in.
I use these things whenever it rains and no rain has entered our Casita. They do not blow off are easy to apply and remove and very effective. Good luck. I'm really thankful to those owners who like most, really loved their Casita.
02-25-2019, 09:01 AM
#55
Hi Glen,
Your awning looks different, is that an original Casita awning?
02-25-2019, 07:20 PM
#56
Originally Posted by RustyCutter
Hi Glen,
If you are referring to post #6, Glenn's trailer is an Escape, not a Casita. I believe Escape installs Carefree awnings, while Casita installs Fiamma awnings.
02-25-2019, 08:17 PM
#57
Who? Me?
Yup, it's an Escape and the awning is Carefree of Colorado Fiesta.
02-26-2019, 07:39 AM
#58
Trailer: 13 ft Boler 1986
Originally Posted by Rzrbrn
How do you keep your RV ventilated during period of heavy rain in hot weather? I have MaxxAir Window Maxx air vents on my Casita but they are no longer made, and I cannot find any knockoff or substitute for this type of product. I now own a BigFoot and it has the same type of sliding windows.
We have sliders on our boler and venting in rain was also a problem. We installed spring loaded awnings over the two side windows. They are actually over-the-door awnings from big rigs. You can adjust how far unfurled they are.
Bizzian
