VMax Tanks 31 XTR31-135 135AH AGM battery - Fiberglass RV
Old 07-15-2020, 08:42 PM   #1
Komrade's Avatar
West Virginia
All,
I had a Group 27 Interstate in my 2016 Casita.. It didn't seem to last 4 years, and I know previous owner and myself always had the Casita plugged in. (I think it was bad when I got the trailer 18 months ago).
I researched, and couldn't find if group 31 would fit, although I've read somewhere Casita now ships new units with group 31.
Group 31 is same width Group 27 but a little taller, and a little longer, and most importantly 50%+ more capacity (135ah vs 88ah in interstate G27)
Anyway, I wanted to confirm if anybody is searching that this model fits.
I had to create a new aluminum bracket to make sure battery doesn't shift sideways, which I created out of a 1/6" x 3/4" aluminum angle iron.. Slightly bigger (1") may fit, but original wouldn't (door would not lock, and if you cut it down, it may still be too thick and you won't be able to reuse the bolt).
I then drilled a hole closest to the edge in the middle, flipped the bolt as there was only enough space on bottom for a wing nut and looks like a factory install (see pic).
VMAX says these will last up to 10 years or 900-3500 cycles if you don't discharge more than 50%, plus offeres half the discharge rate of other AGM batteries (1-2% per mo).. that's a 10% discharge tops over winter. https://www.vmaxtanks.com/FAQ_ep_42.html
I saw other campers use these and recommend.
Will the on board Casita charger suffice?
Q: What kind of charger is best for my VMAXTANK?
A: A 14.5V Constant Voltage Three Stage AGM battery charger must be used to charge VMAXT batteries. These chargers - AKA: Smart, Automatic, Microprocessor Controlled, IEI- have three charging stages that changes as the VMAX charge increases. It switches from Bulk to Acceptance to Float. Please Click on "Description" tab of any battery to get charger ratings for that battery.
Komrade is offline   Reply With Quote
Old 07-16-2020, 06:15 AM   #2
Komrade's Avatar
West Virginia
info on Parallax I found
Parallax Converter Charger - The Casita Club Forum - The Casita Club Forums
Old 07-16-2020, 12:08 PM   #3
Arkansas
I can vouch for VMaxtanks batteries. I have had a 125AH solar AGM in my SOB 5th wheel for five years and no sign of it wearing out. I also have one of their AGM deep cycle batts on my boat trolling motor. They are a "true" deep cycle, not the dual purpose type. Sorry I can't answer about Casita charger.
Flydog is offline   Reply With Quote
Old 07-16-2020, 12:16 PM   #4
Komrade's Avatar
West Virginia
This should have said "drilled a hole closest to the inside edge in the middle. Meaning closest to the 90 in the angle iron.
I created a pilot whole followed by 1/2 bit. I did use a nail from the bottom to scratch the rough opening on the angle iron.
battery
Thetford 135 vs 335 Porta Potti? XBeatzX General Chat 2 05-27-2019 12:07 PM
Casita Battery Charger mods for adding a AGM battery? doctoruv Electrical | Charging, Systems, Solar and Generators 2 02-14-2019 01:51 PM
remember the US dollar is worth $135.00 in Canuck Country stude Referrals: Molded Fiberglass Trailers 2 12-17-2015 04:28 PM
Got a 2nd battery, AGM, 2 questions?! dylanear Modifications, Alterations and Updates 13 07-28-2012 02:47 PM
WANTED, Thetford 135 toilet Kevin K Classified Archives 5 11-14-2007 11:17 PM
