weboost drive reach RV mod - Fiberglass RV
Old 04-03-2021, 02:23 PM   #1
Trailer: casita freedom
Im stuck on this install... How do you attach the antenna to the fiberglass. I'd prefer it on the side and not the roof. Do you have to have a pole? The weboost shows install on the ladder which I do not have. Has anyone done this and willing to send pictures / advice? thank you so much
echarteris is offline   Reply With Quote
Old 04-04-2021, 09:02 AM   #2
MN
I made a pole out of PVC that I gear tie to my propane tank.
scamphound is offline   Reply With Quote
Old 04-04-2021, 09:30 AM   #3
Raspy's Avatar
Trailer: Roamer 1
Smith Valley, Nevada
The WeBoost RV65 comes with a a telescoping antenna pole. They say to attach the pole brackets with clips glued to the trailer side, but I don't like that system.
So, I mounted a piece of schedule 40, 2 1/2" PVC conduit on my spare tire bracket, about 20" long. The antenna pole slides into the pipe perfectly. The pole is completely secure and can be turned by hand to aim the antenna.
The coax antenna cable dangles down from the antenna and runs forward, up through a window and connects to the booster. When done, just slip the pole up out of the pipe, collapse it down and put it in the storage locker with the antenna and coax still attached.
I prefer the directional antenna the RV65 kit provides because it gives a stronger signal than the omnidirectional system. You have to be able to turn the antenna to point it at the tower, so the pole mount should make this easy.
When all hooked up, switch your phone's "airplane mode" on, and then back off. This makes the phone look for a new signal, which will be your booster.
Here is a pic of the pole socket:
Old 04-04-2021, 10:45 AM   #4
Trailer: 2014 Parkliner 2016 Honda Pilot
How long is the telescoping pole when collapsed?
neparker is offline   Reply With Quote
Old 04-04-2021, 03:55 PM   #5
Trailer: Casita - 2019 SD17
Idaho
WeBoost Telescoping Antenna Pole
According to the seller, the pole is 75 inches when collapsed. A 25 foot telescoping pole for the antenna is included in the package to which I provide a link below.
Here is the Amazon link I was looking at https://www.amazon.com/weBoost-Conne.../dp/B07BWFYWNN
According to the ad, here is what is included:
  • WHAT’S INCLUDED — Connect RV Booster, Outside Directional Antenna (314475), Inside Panel Antenna (311155), 2 White Low Loss RG6 Coax Cable 30 ft. (950630), 2 White Low Loss RG6 Coax Cable 15 ft. (950615), Flat Window Cable (951177), F-Female to F-Female Barrel Connector (971129), AC/DC Power Supply 5V / 4A (850012), 12V DC Fused Hardwire Power Supply (851111), Telescoping Pole (Up to 25') and Mount Assembly (900203) and Installation guide
Bob Penn is offline   Reply With Quote
Old 04-04-2021, 08:26 PM   #6
Raspy's Avatar
Trailer: Roamer 1
With the antenna attached, it is about 77" fully collapsed.
WeBoost Mounting on Hunter Compact / Campster Dax Electrical | Charging, Systems, Solar and Generators 8 04-03-2021 02:52 PM
big MOD's of our 1981 Scamp "Mod Pod" CAROLPHAYES Modifications, Alterations and Updates 26 06-11-2014 09:38 AM
How do you reach it? Center Trim on Roof. D Davis Problem Solving | Owners Helping Owners 14 04-09-2013 12:59 PM
Front wheel drive, rear wheel drive, all wheel drive, and weight-distributing hitches Meg A. Towing, Hitching, Axles and Running Gear 14 04-26-2011 09:04 PM
The $49,000 15' Airstream "Design Within Reach" Patrick M. General Chat 12 06-06-2007 06:00 PM
