What Laminate Flooring did you use? Would you use the same brand again? - Page 2 - Fiberglass RV
Go Back   Fiberglass RV > Maintenance | Restoration | Modifications | Problem Solving > Modifications, Alterations and Updates
Click Here to Login
Old 01-13-2012, 10:11 AM   #21
I have been considering doing wood flooring but I wonder how/what people with laminate do to stop things from sliding around on the floor when towing? I keep my bin of trailer stuff (hoses, cables etc) & my portable gas fire pit on the floor of the trailer when towing and they do not shift around on the carpet - worry that they will slid around on the laminate......
Old 01-13-2012, 04:45 PM   #22
Trailer: 1972 Trillium
Nova Scotia
Originally Posted by CliveAlive View Post
Mine's in the Registry.
Very nice floor, did you use an underlay?
Thanks
Harvey
Harvey9 is offline   Reply With Quote
Old 01-13-2012, 08:03 PM   #23
WildBirder's Avatar
I recently remove my old linoleum and replaced it. I purchased a cheap remnant from a flooring co. for thirty bucks. I also used a cork underlay with a built in vapour barrier from Home depot, another thirty. Rather than dealing with glue I went for a double sided tape adhesive (meant for linoleum flooring) called Rhino Grip. I used the extra strength kind. The theory is you just have to use it around the perimeter. It stuck extremely well. So well in fact that I had a really hard time peeling it back so I could add a whole other role to all of the centre areas where the lino had bubble up Two roles at ten bucks, total floor redo cost of $80. Plus way more time than anyone probably using Allure. It was a light weight and very cheap solution. I like my floor it's soft and warm. If you skipped the underlay and taped properly from the start you could do it for around fifty bucks and in not much time. Trim is a different story.
WildBirder is offline   Reply With Quote
Old 01-13-2012, 09:10 PM   #24
CliveAlive's Avatar
Trailer: Boler American (#3104)
Thanks
Harvey
Thanks Harvey. No, no underlay was used.
Old 01-14-2012, 09:30 AM   #25
trilliumdon's Avatar
Trailer: 1975 BIOD Extase
Originally Posted by iplumb View Post
Do you guys have any pictures of your Allure floors? Thanks
I have posted some pics of my interior on my registry page. Very happy with the Allure flooring.
trilliumdon is offline   Reply With Quote
New Flooring-Laminate or Vinyl Tim Wood Care and Feeding of Molded Fiberglass Trailers 49 03-08-2015 03:11 PM
Laminate flooring trim Robin H Problem Solving | Owners Helping Owners 14 07-14-2007 06:36 PM
carpet vs laminate Al & Donna Modifications, Alterations and Updates 37 03-18-2007 11:12 PM
Laminate Flooring Chris Seddon Modifications, Alterations and Updates 5 05-17-2006 11:31 PM
