Your favorite reading lamp? - Fiberglass RV
Old 02-25-2019, 04:36 PM   #1
Name: John & Gloria
Trailer: Bigfoot 21RB
We have a 21RB Bigfoot. I want to mount two reading lights over the dinette. Our dinette is in the front of the rig and my wife and I usually sit with our back to the front window and our legs up on the bench. This puts the existing light too far forward to see the page without turning the book quit a bit. I want a separate light for each side. If you have found a dandy light that works for you, I would be interested. My wife is thinking free standing battery operated. I am wanting to mount 12V lights under the cabinets over our heads. The sabers have not come out yet but with your help, I may have a better chance.
Travelin2 is offline   Reply With Quote
Old 02-26-2019, 10:11 AM   #2
Don't know if this will help, but I'd recommend something with a neck you can adjust and positioned more behind you than straight above you. We have overhead lights in our teardrop we thought would be good for reading in bed. But when we're lying down they actually illuminate the outside and top edge of the book rather than the page! With a neck you could position the light just so for small changes in your reading position. You could also test out the position with a cheap battery operated stick-on light first. Don't have any specific recommendations beyond that, and will be interested to see what others say.
margeleept is offline   Reply With Quote
Old 02-26-2019, 10:24 AM   #3
ZachO's Avatar
Trailer: 91 Bigfoot 17
Montana
Are you mostly plugged in, or do you often boondock? Personally, my favorite reading lamp would be an actual 110V, household lamp with an incandescent bulb, or the warmest LED I could find. If you regularly boondock, then finding an actual 12v lamp would be nice, I would think. Overhead lights are nice, and they're what I use for reading, because they're all I have, but I think a lamp with a gooseneck, like Marge mentioned, would be really nice.
It's something that's been on my list but just hasn't made it to the top yet...
Old 02-26-2019, 11:29 AM   #4
NASA42's Avatar
Travein2.....
Not disagreeing with others' suggestions, but I took another route to satisfying my reading light issue. I replaced the 1141 led bulbs that came in my 2016 Casita's interior side overheads with higher output leds in warm white(over 600 lumens!). I'm happy with the simpler approach to the issue and the outcome.
Frank
NASA42 is offline   Reply With Quote
Old 02-26-2019, 04:13 PM   #5
Name: John & Gloria
I am thinking of something like this but am hesitant to order it because it doesn't say what type of LED it has and if it can be changed/replaced.
https://www.amazon.com/dp/B07JLDT2Q9...detail_5?psc=1
Old 02-26-2019, 08:38 PM   #6
The RV stores tend to be very limited in LED lighting options.
So let me open your eyes with a plethora of choices from the marine supply stores. Those boaters adore LED lighting and there are a lot of choices of good quality 12 volt LED lighting with lots of choices in reading and overhead cabin lights. This is from Fisheries Supply, a terrific store in Seattle where you can talk to real people (even on the phone) and ask questions about the lights and how good each one is for reading. They have them on display, all powered up inside the store. They have a good shipping department.
https://www.fisheriessupply.com/mari...2Fled-lighting
k corbin is online now   Reply With Quote
Old 03-01-2019, 02:01 PM   #7
Trailer: Northern Lite
Washington, D.C.
Definitely win the battle against freestanding battery powered ones. My wife wanted some of those in the regular house. The batteries are always dead.
She learned.
Joe Monstermaker is offline   Reply With Quote
Old 03-01-2019, 11:06 PM   #8
Mike Magee's Avatar
Trailer: Li'l Hauley
Some led lights, like the puck lights I once tried, have parasitic losses and run the batts down even when not in use. Mostly these are el cheapo lights.
Now I like to use a Zebralight headlamp with a warm white led.
In the '60s, people took LSD to make the world seem weird.
Now the world is weird, and people take Prozac to make it seem normal.
Old 03-02-2019, 03:04 AM   #9
NASA42's Avatar
Mike.......
How can an led light "have parasitic losses" if the switch is turned off????
Frank
Old 03-02-2019, 06:28 AM   #10
Name: John & Gloria
I have learned my lesson also about the warm white LEDs. I put cool white lights through out a previous RV and found them very tiring to the eyes.
Old 03-02-2019, 06:43 AM   #11
CindyL's Avatar
Illinois
We have a problem with our reading lights too in the Silver Cloud. They sit out from the angled wall over the bed, and we are constant whacking our heads on them. I have been looking at new lights with a neck that can be moved back. This thread is is useful.
Trouble is, these lights match the rest in the Silver Cloud, so I am not sure about changing them out at all.
CindyL
1988 Bigfoot Silver Cloud, "The Egg Carton"
CindyL is offline   Reply With Quote
Old 03-06-2019, 11:18 AM   #12
daverosy's Avatar
Trailer: (Li'l) Bigfoot
Find anything you like and make it a warm LED. In my case, I bought (under) cabinet lighting from IKEA, snipped the transformer off and wired it directly into my 12V system, added a switch. I placed it on the underside of my cabinets (below standing eye level), above the bed/table on my 13' L'il Bigfoot. It's been great. EASY!
daverosy is offline   Reply With Quote
Old 03-06-2019, 12:04 PM   #13
Trailer: Chalet Arrowhead
Be careful though. Not all LED undercounter lighting strips are 12 volts. Some are around 30 volts and won't work off 12 volts. Check the output on the power module that comes with it.
Eric
EricJ is offline   Reply With Quote
Old 03-06-2019, 12:36 PM   #14
Trailer: Parkliner
Ohio
We like to keep things simple. I use cheap battery operated headlamps. I can pivot the light down to hit my book in the exact right spot. Great for reading outside at night and anywhere in the camper. And no holes drilled.
DavenBecky is offline   Reply With Quote
Old 03-06-2019, 12:36 PM   #15
Trailer: In the market
Virginia
Defender Industries defender.com is a friend to the yachtsman and to the R.V. crowd as well. They should stock a quality 12V led fixture that will work for you that is reasonably(?) priced.
Conch is offline   Reply With Quote
Old 03-07-2019, 06:30 AM   #16
Name: John & Gloria
Thanks for all the ideas. I have just been ignoring all the lights that plug in to 110. I never thought about cutting off the converter.
Old 03-07-2019, 10:06 AM   #17
Jennifer Minogue's Avatar
Suction cup lights
We have two lights that are LED, have goosenecks, plug into USB ports (or plug in using a cell-phone charger gizmo), and have suction cups on the base to hold them in place. they are heavy enough to be free-standing as well. We have them stuck to the underside of the overhead storage cabinets at the back of the Casita (we have a twin bed model). Easily relocated, no screws or rivets.
unfortunately, can't remember where we got them, but could easily have been IKEA. Or an auto supply store. Or a computer supplier.
good luck,
Jennifer
Jennifer Minogue is offline   Reply With Quote
Old 03-07-2019, 10:55 AM   #18
Civilguy's Avatar
Puget Sound, WA
I think there are a number of light fixtures available with goose necks and swivel heads that would work well if mounted under the cabinets.
Name:	RV Reading Light.jpg
Personally, we tend to use our Kindles and our phones with their illuminated screens for most of our reading.
~ "Discussions should be conducted without fondness for dispute or desire for victory." - Benjamin Franklin ~
Old 03-12-2019, 09:15 AM   #19
OK, I trekked down to the trailer and checked out the suction cup lights I mentioned in a previous post. They have a label on them that says Hampton Bay which means we must have gotten them at Hope Depot.
The suction cup operates like those ones on safety bars for bathrooms - has a lever to really stick it down - you don't just smash it up on the wall. The base is about 3.5 inches in diameter.
Hope that helps.
Old 10-29-2019, 01:19 PM   #20
Trailer: R-Vision & In the market
Massachusetts
My daughter got me a Sunbeam desk lamp at a dollar store for ,wait for it, $1.00 I bought 3 more.
https://slickdeals.net/f/13189183-1-...ree-store-only
Here is the kicker. This lamp which is a very good quality with a nice weight to it has a 12volt wall wart with it. So if you wanted you could wire it into the 12 volt side of your RV.
ThomasC is online now   Reply With Quote
Reading Lamp LED - Converison Larry C Hanson Electrical | Charging, Systems, Solar and Generators 2 06-13-2013 05:58 PM
LED desk lamp in Costco. GeorgeR Care and Feeding of Molded Fiberglass Trailers 2 02-06-2011 02:11 PM
Reading Lamp for 12 VDC Larry C Hanson Problem Solving | Owners Helping Owners 0 06-28-2009 02:09 PM
Any info on Coleman propane lamp? Bobbie Mayer Problem Solving | Owners Helping Owners 12 08-08-2007 09:53 PM
Humphrey opalite lantern/lamp Angelo F. Classified Archives 1 08-03-2007 02:35 PM
