Propane Use In Winter - Page 2 - Fiberglass RV
Old 09-02-2020, 04:34 PM   #21
Trailer: 2003 21RB Bigfoot
Coos Bay, Oregon
Question
Not the OP's question but it is a big IF you can even go this year. https://www.cbsa-asfc.gc.ca/services...s-eng.html#er1
Has it been deemed "non-discretionary" travel? Do you need to quarantine for 14-days? Best to call to confirm. Only 5 POE's are currently open.
South Coast Stu is offline   Reply With Quote
Old 09-02-2020, 09:11 PM   #22
Good evening, we lived in Alaska for 10 years, three in a 31 ft Airstream. There’s a book in that adventure. Temps outside are not as important temps inside the trailer. It can be 40 below outside but if inside it’s 40 above you’re good, cold but good.
Here’s what I’d do if I was making that trip. I’d buy propane and gas every time I could, try to keep the tanks as full as possible. I’d make every effort to plug in at night, Not having electricity is a big deal at 10 below. The colder outside the colder inside your fridge, It gives frozen vegetables a new meaning. If it’s real cold there can be condensation in the trailer a lot of it. Four season trailer or not water will accumulate below the windows, inside cabinets, Where the bed covers meet the walls, puddles of water can be everywhere and anywhere.
One more thing, just because the sun is out doesn’t mean it’s warm outside. The trailer can freeze up in the daylight just as easily as it can at night. You may have to run the furnace during the day to keep the temps up.
In truth the temperature in the trailer has to be below freezing for several hours or even days depending on the ambient, before the water lines start to freeze up.
I wouldn’t drive after dark, and I’d avoid boondocking. I would try to get through northern BC, the Yukon, and eastern Ak as quickly and safely as possible. Check on road conditions frequently and don’t believe everything you read in the Milepost.
You’re going early enough - you’ll be fine. Just be prepared.
I wish I was going with ya.
Chick is offline   Reply With Quote
Old 09-03-2020, 12:01 AM   #23
Trailer: Escape 17B
Alaska
Travel Restrictions
Others have mentioned travel restrictions, but here are some links with details.
https://www.reddit.com/r/alaska/comm...tm_name=iossmf
https://www.newsbreakapp.com/n/0Wnxz...a3&pd=06CHGWwd
My apologies if you have already researched this.
Brooks Wade is offline   Reply With Quote
Old 03-14-2021, 11:04 PM   #24
Borden's Avatar
Name: Borden and Carole
We live in Canada. Furnace, hot water tank and fridge can use propane up. Last trip we used 110 for fridge instead of propane it helps. We are trying to use only sites with pwr these days. Water would be nice but none of our favorite campgrounds have water to trailers. A couple of years back we decided on no more non-serviced campgrounds. Some campgrounds in the area want you to have a washroom or at least a porta potty in the trailer and other restrictions.
Our postage stamp in heaven.
Old 05-04-2023, 09:36 PM   #25
Trailer: ford
mexico
Depending on energy consumption, the amount of propane used by the RV refrigerator is about 1.5 pounds of liquefied petroleum gas. 20 lb Propane Tank contains about 4.6 gallons of propane, these gallons weigh 37 lbs when filled up. This can give your fridge enough juice for around 11 to 12 days if it runs 24 hours per day.
Natalie21 is offline   Reply With Quote
Old 05-22-2023, 10:10 PM   #26
Trailer: ford
mexico
Depending on different propane tank sizes, We can identify and calculate how much propane a camper fridge use.
Old 05-23-2023, 06:32 AM   #27
Perryb67's Avatar
Trailer: 2016 Bigfoot 25RQ
Most of this thread was written in 2020.
We went from an Escape 5.0 with two 20# tanks and a 12,000 btu LP input furnace, to our current 25RQ Bigfoot with two 30# tanks and a 16,000 LP btu input furnace, so just furnace size alone it uses 33% more propane an hour. That's significant.
On the negative side, the Bigfoot is wider, longer, with considerably more cubic feet to keep warm and part of the heat is used to keep the fresh, grey, black tanks and valves from freezing, it will use even more LP than smaller campers. The plus side is the superior insulation and true double pane windows.
This past winter (2023) in Arizona, New Mexico, and Utah, was the coldest winter we've experienced. Woke up to snow on the ground at least eight times, and well over half the nights were below 30F, with many in the teens and a few 4-10F mornings. We were going through a 30# tank in 3-4 days, and since the cold never let up, we figured we used more LP last winter than all the LP we used in our Escape the previous four winters combined.
Comparing the LP use of small campers vs large campers is like comparing the MPG of a Hummer vs a Prius. Because of the increased cubic feet of our Bigfoot, requiring a larger furnace, we knew at best we'd easly use as much or more LP. Thanks goodness we had two 30# tanks instead of 20#'ers.
Food for thought,
Perry
Perryb67 is offline   Reply With Quote
propane
South Texas Travel Trailer Owner Inquiry – Winter Weather, Winter Roads, and Freezing ridergw2001 Care and Feeding of Molded Fiberglass Trailers 14 02-03-2018 08:32 PM
Winter Use LeslieGErickson Care and Feeding of Molded Fiberglass Trailers 9 10-04-2016 03:28 PM
Winter battery use question. Ray Cover Electrical | Charging, Systems, Solar and Generators 25 06-18-2015 07:22 AM
What do you use when gone from home in WINTER? Kevin K General Chat 19 01-31-2015 12:01 AM
What Laminate Flooring did you use? Would you use the same brand again? iplumb Modifications, Alterations and Updates 24 01-14-2012 09:30 AM
