Advice needed for Scamp tire replacement - Fiberglass RV
Old 06-08-2024, 02:19 PM   #1
Just like me, my Scamp's OEM tires are getting fairly bald. Unlike me, replacements are available. A little shopping yielded some questions that ya'll may have solved already. My 2021 Scamp 16 Deluxe came with 175-80-13 Globaltrax tires. These seem to be the cheapest option available, at around $60 online. Their load rating of 1610 lbs each adds up to near the 3000-lb measured weight of my loaded trailer. There would be a financial benefit to using my unused spare tire now and buying just one of these. But should I stretch for something better and safer?
I'd enjoy a little more ground clearance, so how about an upsizing to 185-80-13? This would add 100 lbs of rating for each tire. One downside is that I'd have to buy three. And it's still a low-market tire.
Discount Tire has two choices, an $80 Carlisle and a $100 Hankook. The Hankook ups the speed rating by 12 mph to 85, not that I'd drive that fast with a trailer.
Then there's the option of a 14" conversion. That would require buying three wheels and three tires, which I don't desire to do. But a 16" Scamp on 13" tires does look like a hippo on roller skates, so there's that.
So far, I'm undecided. Seems like good arguments for each course of action, so go ahead and sway me...
John McMillin is offline   Reply With Quote
Old 06-08-2024, 02:52 PM   #2
Buy the Carlisle Radial HD 175/80-13.
Keep your best used tire for your spare.
IMO this is the best small trailer tire on the market by some margin,
it also contributes significantly to handling, which I have not
seen in any other trailer tire.
Going to a 205/14 in an appropriate load range and size
would only add 1" in trailer height at a substantial cost.
You don't mention the year of your Scamp but if it is fairly new then a road clearance increase can be accomplished with a spacer added to the axle at the frame.
This seldom needed and has its own set of drawbacks.
Contrary to conventional wisdom, it can be detrimental to increase the load range beyond what is best for the trailer.
Old 06-08-2024, 03:12 PM   #3
A GVW of 3000# means an axle weight around 2700#.
Old 06-08-2024, 07:20 PM   #4
I understand that the tongue weight doesn't count...
But there's the matter of keeping a safety margin above the specs.
Old 06-09-2024, 08:07 AM   #5
Agree. But how much is appropriate? I have never heard a solid answer to that, and as a result a "more is better" mentality predominates. In the Scamp groups I have read people seriously advising load range E for a 13' Scamp (it doesn't exist, so don't look).
3200-2700=500# margin, which is a little less than 20%, which is about the minimum I'd want. You also have to factor in that many trailers are heavier on one side. If you're not comfortable with that, the only way to gain additional margin is with 14" wheels. If you did go to 14", you have more tire options, including the well-regarded Goodyear Endurance ST. I'd personally be inclined to spend the money.
I agree with Floyd that at some point you can go overboard, wasting money, resources, and decreasing ride quality.
Old 06-09-2024, 10:47 AM   #6
jerrybob's Avatar
Trailer: casita
I think the Maxxiss M8008 tires are one of the best. I am on my second set on my Casita.....I use E rated but they make a C rated in your size. Great tires! I replace every 5/6 yrs.......not because of wear.....because of age.
jerrybob is offline   Reply With Quote
Old 06-10-2024, 10:40 PM   #7
Thanks for the advice I've ordered a pair of the best Carlisle trailer tires, in the OEM size and load level D. The speed rating rises a notch, at least.
Door repair advice needed Perris Pacer 1975 (Scamp parts may work) Roxi Problem Solving | Owners Helping Owners 0 09-18-2022 05:22 PM
Advice needed on resting Scamp shell on its frame K Ann Problem Solving | Owners Helping Owners 2 05-02-2021 08:22 AM
1992 Scamp Fixer, need advice on some needed parts lisantica Problem Solving | Owners Helping Owners 16 10-22-2017 05:47 AM
1976 Scamp PO attached bunk to shell, advice needed Curbfeeler Problem Solving | Owners Helping Owners 7 10-16-2017 09:15 AM
tire cover help needed! Daisy Problem Solving | Owners Helping Owners 3 06-20-2006 05:30 AM
