Anyone towing a 13 casita w/bath using Jeep Wrangler - Fiberglass RV
Old 08-01-2020, 08:57 AM   #1
Trailer: 2010 Little Joe / 2010 2 Dr Jeep Wrangler
Considering a 13 casita
I have a 2 dr wrangler w/6 culture
6 speed manual & tow pkg
All the specs on Jeep and trailer work
Just looking for real life experiences
Old 08-01-2020, 09:33 AM   #2
Trailer: U-Haul 1986 -- got it 7/2013
Virginia
I towed my 13-foot U-Haul (no bath, no brakes) with a Wrangler (2-door, 6-cylinder, short wheelbase). Worked pretty well, except for once - it was raining and I had to apply the brakes pretty vigorously. The front end of the Jeep started to skid. I figure the downward braking force on the hitch (see-saw effect) unloaded the front wheels enough to break road traction. There were no adverse consequences.
I no longer have the Jeep (unrelated reasons) and presently tow the thing with a V8 Silverado. I can hardly tell it's there.
Pete Hein is offline   Reply With Quote
Old 08-01-2020, 09:53 AM   #3
Fred-Linda's Avatar
Name: Fred & Linda
Trailer: Little Joe
We tow our Little Joe with a short wheel base Wrangler with no problem. We make monthly trips around our state of Texas and usually two multi-state trips annually mostly to the mountains of Colorado, Utah, and New Mexico.
We are in our third Wrangler. Just use a little driving common sense and don't take unnecessary chances. I sometimes upset drivers behind me but I would rather drive 10 miles under the speed limit than 10 miles over.
. . . . Fred
Fred-Linda is offline   Reply With Quote
Old 08-01-2020, 10:15 AM   #4
PCO6's Avatar
Trailer: Cadet
. . . . Fred
Fred - I put a "Jeep" sticker on the back of my trailers just so drivers behind me know why I might be going slow from time to time.
PCO6 is offline   Reply With Quote
Old 08-01-2020, 10:26 AM   #5
Fred-Linda's Avatar
Name: Fred & Linda
Trailer: Little Joe
Ha - - - good idea.
I almost bought a bumper sticker that says "Retired, go around".
Old 08-01-2020, 11:11 AM   #6
IllAnnoy
All with normally aspirated 4CYL engines use to tow my Scamp13D front bath.
Each did very well in all conditions including great fuel mileage.
The Escapes were both 5spd manuals.
The TC is a 6spd Automatic and 105"WB
Old 08-01-2020, 01:26 PM   #7
Name: Bob & Jackie
Trailer: 17' Casita Spirit Deluxe
CA,AZ
Jeep Wrangler/13' Scamp
Hi there,
Just couldn't help but add my two cents to this topic. We towed a 13" Scamp for 3 years behind a Jeep Wrangler 4 door. Not the best vehicle for towing, but we made it work with not driving fast and added brakes to Scamp for better control. Wrangler has a short wheel base and not a lot of power, even for a 6 cylinder. Added better shocks, better tires and even worked the rear end gears to get the control needed. Eventually moved up to a Toyota Tacoma 4x4 with towing package. Use the Tacoma for towing our 13 Scamp and 17 Casita Spirit Deluxe.
Bob & Jackie C is offline   Reply With Quote
Old 08-04-2020, 09:53 AM   #8
Trailer: Beachcomber
BC
We use our stock automatic 2018 Wrangler Sahara to tow our 13' Beachcomber. It's around 2000 lbs loaded. Tow it through the mountains of BC. Slightly underpowered but decent tow vehicle. Having brakes on the trailer makes it easier as well. We opted for the .373 gearing as well.
ysreeps is offline   Reply With Quote
Old 08-04-2020, 10:21 AM   #9
while we don't have wrangler we have a 1974 ford Bronco and a 2006 Jeep liberty and both have towed our 13 Scamp. when loaded the Scamp pushes close to 2200 lbs everything we towed it with does fine but we do not have any 4 cylinder engines. we have driven them from seal level to 9,000 feet elevation. The key that makes it all work is the electric brakes on the trailer. I do not like towing with out brakes on the trailer. Take your wrangler and go to u-haul and rent a small box trailer for the day and drive around pretty close approximation.
Old 08-04-2020, 06:21 PM   #10
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
Have towed our 13’ Scamp with both a TJ (manual straight 6) and a JK(V6 automatic) both did fine because of trailer brakes. I had a Scamp without brakes push our Jeepster Commando through an intersection on dry level pavement.....put trailer brakes on it after that. Wolf Creek pass kept us in 1st gear @5000 rpms for 20 minutes to make it over with our TJ & JK (both 2 door models). Take your time and you’ll do fine.
Dave & Paula
casita
Jeep Wrangler, Short Wheelbase, for Towing John Hussey Towing, Hitching, Axles and Running Gear 26 01-02-2018 05:35 PM
1991 jeep yj wrangler lifted Jdunbar Classified Archives 0 07-03-2015 06:52 PM
Towing Scamp with Jeep Wrangler Mark Saiger Towing, Hitching, Axles and Running Gear 20 03-12-2012 10:25 PM
Towing Mirrors - Jeep Wrangler Ryaine Towing, Hitching, Axles and Running Gear 9 05-28-2011 10:58 AM
So long Jeep Wrangler... Nor_Cal_Todd Towing, Hitching, Axles and Running Gear 11 10-06-2010 08:03 PM
