Axle flip? - Fiberglass RV
Old 03-25-2024, 03:39 PM   #1
YourHighness's Avatar
Trailer: Burro
Alabama
Axle flip?
I have a Burro 13’. Has anyone flipped their axle end-for-end to change their center of gravity?
YourHighness is offline   Reply With Quote
Old 04-14-2024, 10:43 AM   #2
FL
Not familiar with your application but have done it to a bunch of hotrods. May need to add centering pin . Lot can also be done with lift/drop blocks. Might want to try some ratrod forums as this is a pretty common modification .
mosquito13 is offline   Reply With Quote
Old 04-14-2024, 11:14 AM   #3
Trailer: Burro
Alabama
This is probably not something that is commonly done and you’re the only one who has replied so thank you for your suggestions.
Old 04-14-2024, 03:26 PM   #4
FL
Like I said try the hotrod or off roader forums. People seem a little more adventuresome in modifications. I used blocks and did a write up when I upgraded lifted my axle and worked on my frame . https://www.fiberglassrv.com/forums/...ft-101152.html
Old 04-14-2024, 08:22 PM   #5
Do you mean changing from lead to trailing, or vice-versa?
Old 04-14-2024, 10:11 PM   #6
Raspy's Avatar
Trailer: Roamer 1
Smith Valley, Nevada
Don't Burros have torsion axles? "flipping" the axle is done with leaf spring/straight axle suspension, not torsion.
Old 04-15-2024, 02:06 PM   #7
Check where your axle mounts are located, and whether if turning the axle around may not provide adequate clearance inside the trailer wheel wells for axle motion. You might need to move the mounts on the frame too. Just something to check first...
Old 04-16-2024, 12:21 PM   #8
As far as "changing your trailer's center of gravity," whether you have a leading or trailing axle, it really won't change your COG any. It will still have to be centered in the wheel well to assure that the flex of the torsion arms will have adequate clearance to not rub the tires against the wheel wells. This basically means, that you won't achieve any gain in reversing the axle to move your trailer's center of gravity just by reversing the axle.
Old 04-17-2024, 11:01 AM   #9
Trailer: 2024 Escape 5.0TA
Did an axle flip on a Coleman tent trailer (leaf spring axle) years ago to get more clearance in wheel wells. Worked out great, however I'm not familiar enough with the Burro configuration to know if it will work for you.
jjdeluca is offline   Reply With Quote
Old 04-19-2024, 12:30 PM   #10
Trailer: Burro
Alabama
You’ve go it. That’s exactly what I’m contemplating.
Old 04-19-2024, 12:31 PM   #11
Trailer: Burro
Alabama
I would have to weld new mounting brackets for the axel to accomplish what I’m thinking.
Old 04-19-2024, 12:33 PM   #12
Although I know Casitas very well, inside and out, but I will say I don't know squat about Burros. So, do you have a "rubber band" axle, like the Dexter Axles, or does Burro use leaf springs?
Old 04-19-2024, 12:35 PM   #13
Trailer: Burro
Alabama
Since the center of the wheel and the center of the axel is separated by about 5” or so behind the wheel center, flipping the axel would then place the axel CG about 5” forward of the wheel. Am I missing something?
Old 04-19-2024, 12:37 PM   #14
Trailer: Burro
Alabama
My Burro is a torsion axel setup and the wheel sets about 5” forward of the axel.
Old 04-19-2024, 12:42 PM   #15
If it uses a torsion axle, (similar to the Dexter my trailer has, have you considered installing a "high lift" axle kit to raise your trailer's ground clearance? They mount under the frame where the axle is installed, and then the axle mounts to the lift kit.
Old 04-19-2024, 06:07 PM   #16
Trailer: Burro
Alabama
My TV is a 2011 Rav4 w/v6 with a rear swing door and not a hatch. The trailer currently sits level but If I raise the camper I would have to raise my ball hitch which would then interfere with the back door opening.
Rudy
Old 04-19-2024, 06:46 PM   #17
Trailer: 2013 Escape 19
The Mountains of NC/SW Desert of UT
Typically these axles (if they are original equipment) are beyond their predicted life span. So at that point, people replace them with a new axle with more lift.
Old 04-23-2024, 05:38 AM   #18
Trailer: ex-Casita, now Alto R series
Massachusetts
My Burro is a torsion axle setup and the wheel sets about 5” forward of the axle.
The change to the Cg by moving the axle from 5 inches behind the wheel to 5 inches ahead of the wheel will be not all that much. How much does the trailer weigh? How much does the axle weigh? What is the percentage of the axle weight relative to the whole unit?
Now, how much will that Cg move by shifting that axle weight from 5/12 of a foot behind to 5/12 of a foot ahead? I expect that (reading between the lines here) simply adding less than an axle's weight but further forward of the wheels, will provide more tongue weight and more effectively move the Cg.
How about a 30 lb tank of propane on the tongue instead of a 20?
Jon MB, (the lesser half of Bonnie RB )
Jon MB is offline   Reply With Quote
Old 04-23-2024, 09:20 AM   #19
If I'm understanding this confusing thread correctly, it sounds like the OP has a torsion axle in leading configuration and wants to change to trailing. (That is not what is normally meant by "flipping" an axle, hence the confusion.) Leading is a non-standard configuration, and it can have some undesirable handling characteristics under some conditions. I think changing to the standard trailing set-up is a good move, Cg aside (which I don't think will be affected much). I don't know enough about the Burro frame configuration to know how feasible the conversion is, but a qualified axle installer could have a look and tell you whether any frame modifications or changes in axle specs might be required.
If the axle is original, it's probably due for a new axle rather than re-installing the old one. The rubber in a torsion axle breaks down over time. If it doesn't already have brakes, now is the time to add them, or at least get an axle that's prepped for brakes.
With any modification that might affect the fore-aft balance of the trailer, it's important to check your weights afterward and verify tongue weight is within the safe range (10-15% of trailer weight). Adjust loading as needed.
Nobody has yet asked the $64K question, so I will. Why do you want to change the Cg?
axle
Axle Flip for More Clearance mosquito13 Towing, Hitching, Axles and Running Gear 13 02-08-2020 02:25 PM
2002 Bigfoot 21RB axle flip Travelin2 Towing, Hitching, Axles and Running Gear 4 09-25-2018 04:29 PM
Flip Bigfoot axle? eryork Towing, Hitching, Axles and Running Gear 25 04-20-2016 08:36 PM
Over to under axle flip? KSM Modifications, Alterations and Updates 7 05-21-2015 04:03 PM
The Flip Side, From Fiberglass Eggs Adrian W General Chat 8 05-14-2011 05:22 PM
