Alan My 93 "lil"
Bigfoot has a leading link Dexter axle. The axle is set on a part of the frame in the wheel well, that changed from parallel lines (left and right sides) to a 13 degree angle inward toward the center of the trailer. 49"s wide at wheel well 2' wide at the front of the frame. where it comes out from under the trailer. The brackets welded to the axle are set at 13 degrees out of square. I am trying to figure out how to add brackets to the angled part of the frame to make it a parallel line along the wheel well. allowing me to change to a trailing link axle.
Later Kenny
