Backing Uphill Driveway to Park - Fiberglass RV
Old 02-13-2024, 09:32 PM   #1
Trailer: Currently Shopping for Scamp, I think ...
Backing trailer uphill
Moderator's note: two threads on same topic have been merged here, with a couple of duplicate posts removed. Carry on, Garth.
Hi FG RV Community,
Will my 2022 Highlander Hybrid 3500lbs tow capacity vehicle be able to back a 17b up my driveway??? Mine is a short and steep uphill driveway that probably is 50 feet long and a 15-foot rise. I see that the 17b has 15" wheels, and I can get a lift. Will that be enough to not scrape my trailer while backing to driveway parking spot? What do you all do to ensure your trailer doesn't scrape?
Thanks, Kk
Screenshot 2024-02-13 at 10.28.40 PM.jpg   Screenshot 2024-02-13 at 10.28.32 PM.jpg
karliefoxk is offline   Reply With Quote
Old 02-14-2024, 07:18 AM   #2
ShelbyM's Avatar
Trailer: Casita SD
What you are asking about is known as approach or departure angle. Here is a link to a calculator. http://https://www.vcalc.com/wiki/Ku...parture)+angle And here is your grade.
If the shoe fits...
Old 02-14-2024, 07:19 AM   #3
jgilliam1955's Avatar
Trailer: Casita Liberty
Virginia
I installed a front hitch on my pickup. 2015 Colorado. It works for me. You may want to look at trailer movers. Do not go cheap. They make them with remote controls now. Trailer movers work on cement but will not work on gravel or grass.
Been with my sweetheart since 1969
2015 Chevy Colorado & 2019 Casita owner
If I won the award for laziness, I would send somebody to pick it up for me.
jgilliam1955 is offline   Reply With Quote
Old 02-14-2024, 07:20 AM   #4
Virginia
Old 02-14-2024, 07:21 AM   #5
Virginia
I have used this in the past. It would not work on grass and had to sell it.
https://parkit360.ca/products/force?...41156456022197
Old 02-14-2024, 11:21 AM   #6
jerrybob's Avatar
Trailer: casita
A couple of 2x6s at the bottom of your driveway would probably allow enough lift to prevent bottoming out......I think your vehicle could handle the load.
jerrybob is offline   Reply With Quote
Old 02-21-2024, 12:13 PM   #7
Trailer: 1977 Scamp 13
i have a steep DOWNHILL driveway on a narrow street with cars often parked on the other side which makes it really difficult to park my trailer. i use a receiver hitch mounted winch which makes parking a breeze. maybe you can rig something up in your garage to pull your trailer uphill and lower it back down.
John LF is offline   Reply With Quote
Old 02-21-2024, 12:29 PM   #8
Vermont
Hi KK, If you want a guess, I don't think you will have a problem. If it is close you can improve the odds by starting along the street line and curving into the beginning of the driveway rather that straight in. Good luck.
Yardsailor is offline   Reply With Quote
Old 02-21-2024, 01:41 PM   #9
Alabama
what I would be careful about is the transmission cog which locks the gears in park. On that hill with all that load, it puts a lot of stress on the cog, especially going in and out of gear, park to reverse or drive.
what I have heard said and what I do is stop with the foot brake then apply the the emergency brake to hold the vehicle in place on my Toyota forerunner then when the vehicle is comfortably stopped and held by the emergency brake I put the transmission in park. This way that transmissing cog isnt holding all the load.
StevenMaria is offline   Reply With Quote
Old 02-21-2024, 01:55 PM   #10
What Yardsailor said. The problem is the transition. It looks like you have plenty of room to enter the driveway at an angle rather than straight on. You could also put a board(s) to flatten out the curb even more. Shouldn't be any problem if you do that. Backing uphill is not fun regardless. You'll be an expert in no time!
Old 02-21-2024, 02:14 PM   #11
You are talking about the parking prawl. Not sure the hybrid transmission works the same or not, but you are correct for conventional transmissions. With your foot on the brake, set the parking brake before shifting to Park, and shift out of Park before releasing the emergency brake. Never let the vehicle roll hard onto the parking prawl.
Old 02-22-2024, 11:55 AM   #12
ShelbyM's Avatar
Trailer: Casita SD
Nissan recently had a parking pawl related recall of Frontiers and maybe some others . Mine wasn't included but after reading so much about it I've become religious in the use of the parking brake.
If the shoe fits...
Old 06-16-2024, 01:23 PM   #13
Trailer: Scamp Deluxe 16ft
Alabama
My driveway would be a nightmare for some then to add to it I was backing up it with a M.T. Jeep Wrangler.
After every rain, I have to replace some of the rocks in washed out spots. I've got to pour more concrete in some of the washed out spots again too. Prior owner had placed material cloth and carpet to help hold soil in place then put down gravel. I started with rocks and concrete to fill in the deep ruts and to hold some of it in place. Clay and limestone are not the best for a driveway.
Darrell in Al is offline   Reply With Quote
Old 06-16-2024, 01:31 PM   #14
Trailer: Lil Snoozy / Silverado
Backing up hill with a manual is both a challenge to the driver and the vehicle. After having owned nearly fifty vehicles in my life I now own two with automatics and one of which with 4wd, Firsts on both counts for me. At 73 years of age it was probably time.
Bill in Pittsburgh is offline   Reply With Quote
Old 06-18-2024, 07:42 PM   #15
Alabama
Backing into narrow driveway. GeorgeR Problem Solving | Owners Helping Owners 30 04-19-2012 07:49 AM
driveway apron too steep? yyyyyguy Problem Solving | Owners Helping Owners 9 02-07-2012 01:35 PM
Driveway Friends jaye580 General Chat 8 08-03-2011 02:37 PM
Storage--where & how for someone without a driveway in L.A.? Erik B Problem Solving | Owners Helping Owners 7 12-09-2006 01:14 PM
