Backup lights - Fiberglass RV
Old 11-16-2014, 10:37 AM   #1
Borden's Avatar
Name: Borden and Carole
Backup lights
Wish to add backup lights to our 17' boler any ideas about lights that would look ok with the standard (original) tail lights; thought a bit smaller and located below the original lights in the recessed
out section.
Has any one else done this. night time parking safety
Our postage stamp in heaven.
Old 11-16-2014, 10:48 AM   #2
Bob Miller's Avatar
I have just added a regular outside mounting porch light to the back of the trailer to use as a back-up light. Placed centered, above or below the back window it looks just like it belongs there and can also be useful for outside lighting at night.
Be sure to match your existing porch light style or the RV Style Police might be knocking at your door late some night.... LOLOLOL
Old 11-16-2014, 11:03 AM   #3
floyd's Avatar
out section.
there are plenty of lights available which would work great.
the question really is... do want them for conventional purposes like notifying traffic behind you that you are backing?
Or do you want to see better when backing into a campsite at night?
If the latter is true, then you might consider placing a single driving light under the bumper out of sight facing downward.
This puts a big pool of light immediately behind the trailer and illuminates the ground under the trailer and on both sides from the tires back.
Our Scamp came with conventional backup lights . My Ranger is wired for them, my Escape is not. There is not much real difference as far as illumination behind the trailer, but they do work as indicator lights.
Old 11-16-2014, 11:25 AM   #4
Rick Mooyman's Avatar
Trailer: 1971 Boler
You should take a run to Princess Auto. They have lots of good choices there. I just picked up a LED light I am going to use as a high mount brake light on my 13' Boler.
out section.
Rick Mooyman is offline   Reply With Quote
Old 11-18-2014, 09:11 AM   #5
Borden's Avatar
Thanks for your ideas: May try the porch light, plus the under light and rear facing light Will connect the rear facing light or lights to the backup switch (wire feed in 7 pin on car) porch light can be manual turn on will try to find one that looks like the original side light.
light, lights
Adding backup lights to TT knighth001 Problem Solving | Owners Helping Owners 9 03-06-2013 06:01 AM
Brake Lights, Turn signal lights, marker lights, oh my! glamourpets Problem Solving | Owners Helping Owners 19 01-03-2013 10:10 AM
Bigfoot trailer backup lights not working MountainHome Problem Solving | Owners Helping Owners 5 04-26-2008 10:37 PM
Backup Power? Art Davis General Chat 3 03-23-2007 08:04 PM
Gray Water Backup Legacy Posts Plumbing | Systems and Fixtures 1 08-04-2003 06:49 AM
