Bent - Page 2 - Fiberglass RV
Old 12-18-2024, 12:18 PM   #21
Trailer: '75ish SurfSide 14'
Manitoba
For my money Fred Smailes has it right ^^. I'm not a certified welder, but I repaired a fair bit of my farm equipment ... and the welds had to "hold" a l-o-t more than a [static] trailer tongue. Now, cracks or a bent frame are horses of a different color.
owenmaura is offline   Reply With Quote
Old 12-18-2024, 01:01 PM   #22
Hammer it back.
Use a BFH and perhaps a second BFH to back up and just hammer it back into place.
This is not a space ship or a BFD.
Look for cracks etc.
If you are worried about the future and cracks, clean the area well and paint with a satin white enamel and after it has dried paint over with a gloss black.
If there are cracks or movement the black paint will break along with the steel and the white will help show the cracks while they are small.
Of course you can throw money at it. When I rebuilt my Scamp frame I used a bulldog coupling like above and I can recommend it, but you don't need a 10,000 coupling.
Old 12-18-2024, 02:28 PM   #23
Trailer: Trillium 4500 1978
The jack mechanism, if the shaft is bent it will need replaced - about $120 online. The bent top plate needs to be set on an anvil and beat flat with a big 10lb hammer if no welds are cracked, it's good to go. It's unlikely there are any cracks, but an inspection with a magnifying glass is good. Any cracks need to be assessed. A Close inspection of the tubular frame for any deformation or cracking is a simple visual inspection. Wire wheel the paint off of any welds for a better view. Have a welder check the welds for damage and reweld any questionable connections.
drdoyle is offline   Reply With Quote
Old 12-18-2024, 04:11 PM   #24
Trailer: U Hall VT
Either a tongue strike while hitched or a false hitch that popped off the ball and hit the pavement. My initial assumption was the latter based on the phrase “off the tow vehicle.” The amount of damage was surprising for a low speed driveway event, but if it’s a heavy tongue with a bit of momentum and the foot caught on something…
OP hasn’t been back. I’m hoping she followed Bob’s initial advice and took it to a certified welder.
What he said, certified welder!
Roger Kimble is offline   Reply With Quote
Bent axle? Arno Towing, Hitching, Axles and Running Gear 15 04-15-2011 07:02 AM
17Ft Bigfoot Axle - bent? Dave_L Towing, Hitching, Axles and Running Gear 10 09-14-2009 12:04 AM
Bent Awning Extension John & Sandy M Problem Solving | Owners Helping Owners 1 04-18-2009 08:57 AM
Bent Axle? Legacy Posts Towing, Hitching, Axles and Running Gear 3 08-04-2003 12:26 PM
bent axle? Legacy Posts Towing, Hitching, Axles and Running Gear 7 07-21-2003 11:18 PM
