11-18-2019, 05:10 AM
Trailer: 2016 Parkliner
Virginia
Bike Rack Weight
I have a 15' Parkliner TT. It is ready for a bike rack to be attached to the rear bumper.
Any suggestions about the max weight that it can hold? We're looking at e-bikes and don't want to buy something we can't haul.
Thanks!
John
2016 Parkliner
11-18-2019, 04:17 PM
I don't Know about Parliner bumpers, or how strong they are. Of course any "sewer hose" type bumpers are automatically unacceptable for any bike rack, let alone an e-bike or two, but I do know that most bike rack manufacturers specifically state that their racks are not to be used on the back of travel trailers. We also have two e-bikes, a Rad City (mine) and a Rad City Step-Thru (the wife's,). They each weigh in at a little over 60 Lbs. each, so we don't carry them on the back of the trailer. Instead we have a Saris triple track, which just sits on the floor of the pickup bed. Don't use anything to support it, it just sits there, not screwed or mounted to anything, and doesn't move move around. Very secure and stable. It does require the removal of the front bike wheel, which also sits in its own U shaped bracket that also attaches to the rail.
https://www.saris.com/product/traps-triple
If your trailer has a beefy enough 2" receiver that can support it, here's a rack specifically made for use with a travel trailer which will carry 2 e-bikes.
https://www.etrailer.com/Hitch-Bike-...an/S64689.html
11-18-2019, 05:05 PM
It's not so much the weight of the rack and bikes, but that a lot of folks do not secure the bikes with bungee cords to keep them from flopping around. Which puts all the load on the Receiver socket.
Also, there's a good chance the bikes will hinder visibility to the tail/stop/turn signals, and that's illegal.
AND, the balance of the trailer gets off. You need to keep at least 10% of the total trailer weight on the hitch ball.
11-19-2019, 09:01 AM
The ParkLiner trailers ARE molded fiberglass, similar to Scamps and Casitas.
11-19-2019, 09:11 AM
Originally Posted by Wayne Collins
used
Did someone suggest otherwise?
11-19-2019, 01:35 PM
Trailer: 2013 Escape 19
Be very, very careful about what such a load on the back of your trailer will do to tongue weight. Measure it to prevent disappointment.
11-20-2019, 07:16 AM
I would be most concerned about the rack attachment. A rack that attaches to the bumper alone will not be sufficient. It should be tied into the frame with multiple points of attachment. Scamp adds an additional frame cross member and welds a receiver tube to that as well as the bumper (which is heavy gauge steel). Casita owners typically install a custom receiver hitch that bolts to the frame in four places, bypassing the bumper altogether.
As said, the rack itself must be rated for installation on a trailer. Most aren’t. Make sure it’s rated for the weight of your e-bikes, which run on the heavy side.
If you can get that far, then you will have to figure out how to adjust the loading of the trailer to maintain 10-12% tongue weight. And you will probably have to install an extra set of high mount taillights.
Bikes, especially heavy and valuable bikes, are a good argument for a pickup truck. They’ll be much happier there.
11-20-2019, 11:04 AM
Trailer: 1986 Play-Mor II & Scamp 13' Build date April 2019
Connecticut
This is what I did
I installed a hitch on my frame
11-20-2019, 11:07 AM
Connecticut
Here is some more
Lots of gussets
11-20-2019, 02:04 PM
Trailer: BigFoot 25B25RT
Massachusetts
Very nice!
11-20-2019, 04:50 PM
Trailer: 2014 Parkliner 2016 Honda Pilot
I have used this RV certified bike rack w my Parkliner
https://www.amazon.com/Swagman-Appro...s%2C177&sr=8-4
It's rated for 35 lbs/bike and weighs 39 lbs. My bikes were probably 25 and 30 lbs. It worked quite well with a sway bar. I tried it without, and additional weight on the tongue just didn't work. The analysis at the time was that sway was due to the bikes being so far aft of the axel -- there was too much leverage exerted by the bikes and rack.
I've driven many miles and over uneven pavement (think I 81 in PA and NY!) with no problems using the sway bar.
FYI -- The Amazon entry for this bike rack includes a comparison table of other RV-certified racks that may be helpful.
-- Anne
11-20-2019, 07:26 PM
Originally Posted by neparker
... It worked quite well with a sway bar.
My concern would be rain. Assuming it is a friction sway bar, they lose friction and therefore effectiveness when they get wet. So I could see sway starting when its raining, exactly when you really want a stable rig.
11-20-2019, 08:19 PM
Bike Rack Weight
Personally I wouldn't tow anything with a sway bar that I wouldn't be comfortable towing without one. A sway bar is a back-up system, not a corrective for an unstable trailer.
We carried two bikes on the back of our Scamp 13 without sway or incident for 5 years, but when the anti-wobble bolt stripped out on the even of a trip, I found a way to carry the bikes inside the trailer. In addition to being secure and protected, the trailer handled noticeably better on curved mountain roads, so much so that I decided to permanently retire the bike rack.
They are easier to load than a rear rack when you consider you have to mount the rack on the receiver, secure the bikes to the rack, stabilize them to keep them from banging each other or the trailer, and cable the whole mess to the frame (for security and as a safety back-up just in case the rack or attachment fails). Saved 35# or so by ditching the rack.
11-23-2019, 12:04 PM
Trailer: Trillium 1300
Hitch mount bike racks?
Has anyone tried a hitch mounted bike rack?
Denise
11-23-2019, 12:26 PM
South Carolina
I have seen several of these and wondered how they work. Looks like a good idea overall compared to a rear bike rack.
11-23-2019, 12:36 PM
Much better, but it will add 75-100# to your hitch weight. Since many people tow molded trailers with smaller vehicles, it's something to take into account. Some molded trailers also have fairly short tongues, so there can also be interference on turns to manage.
All in all, I consider it the second-best way to carry full-size bikes (next to an enclosed pick-up bed or van cargo area).
11-23-2019, 12:48 PM
Trailer: 16 ft Casita
Bike rack
Don't do it the hitch can take the weight but the bike rack can't no matter what the rack maker says can't take the bouncing no matter how well you strap them it will fail .
11-24-2019, 08:58 AM
Trailer: Eggcamper 17 ft Electric
It's been awhile since I posted anything, but here's a solution that I used. If you're handy you can make a rack to hold a couple of bikes inside your camper. I made this one so that it would come apart easily for storage when not in use. The two long narrow pieces are dovetailed into the larger board, but are only held in place by the weight of the bike. I simply placed it on the floor of the camper and then added the bikes. It never seemed to move around much, but if it had, I think adding some rubber to the bottom would have worked.
It's made with a piece of 2x6, another of 2x4, and a couple of pieces of 1x4 strapping. The truck bed clamps hold the fork with the front wheel removed and velcro straps secure the rear wheels on the strapping. Here are a couple of photos:
11-24-2019, 09:03 AM
Trailer: Scamp 16'
Bike transport
We researched this a couple of months ago. The general consensus was that, with a rear-mount rack, all the bouncing will ruin either the bikes, the rack, or the trailer. Not to mention the towability of the trailer.
We looked into the tongue rack, but we have a double propane rack with cover (and battery, and brake thing) and it wouldn't fit well.
We also looked at an adaptor that has a ball for the trailer as well as a receiver for a bike rack. Looked great, but again we didn't have enough clearance due to all the other stuff already on the tongue (the bike would touch the propane cover when turning corners).
We ended up with a car mounted rack and good peace of mind.
11-24-2019, 10:09 AM
Massachusetts
I have several DIY ebikes that I carry inside my pickup bed. The 8 foot bed is covered with the tallest ARE truck cap. I can carry 3 or 4 bikes, less if one is my recumbent tadpole trike.
My latest creation "not done yet" is to tall to fit inside the cap. I've purchased a front mount hitch for the truck as one possibility. I have also noticed that Bigfoot Trailers are quite heavy in the tongue. I may look into a frame mount hitch for my trailer so I am not putting any weight on my rear bumper.
https://www.etrailer.com/RV-and-Camp...urt/13703.html
My best bikes have evolved to about 100 pounds each.
